Old 05-30-2015, 10:50 PM   #1
CA Victoria
CA Victoria's Avatar
Default Remote oil filter plumbing
I'm getting ready to plumb a remote oil filter housing on my F1 with an 8ba. Since it is mounted on the firewall I want flexible lines. I modified the block for full flow and have a stock oil pump. There are a few different types of hoses and fittings available. I would like to know what hose /'fitting types you all have used for your oil systems.
Is 3/8 id hose sufficient?
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 05-30-2015, 11:16 PM   #2
f1builder
Default Re: Remote oil filter plumbing
i went to the local farm and ranch supply and bought a couple hydraulic hoses off the shelf that worked perfectly. cost 10 or 15 bucks. just match up the fittings. did this on my 52 f1.
f1builder is offline   Reply With Quote
Old 05-31-2015, 07:26 AM   #3
V8 Bob
V8 Bob's Avatar
You want to use (min.) 1/2" quality hose, designed/intended for oil, with high pressure and temperature ratings, available from Earl's, Aeroquip, Goodyear etc.
AN fittings are a good and popular choice, mine also.
V8 Bob is offline   Reply With Quote
Old 05-31-2015, 02:37 PM   #4
my4dv8
I have used the "push lock " type hose tails with great success. Easy to fit at home . I think with 1/2" hose you will need a step down to go into the block and possibly your filter connections.
my4dv8 is offline   Reply With Quote
Old 05-31-2015, 02:57 PM   #5
PeterC
PeterC's Avatar
Push type works well for me with high pressure hose cloth covered.
PeterC is offline   Reply With Quote
Old 05-31-2015, 04:15 PM   #6
CA Victoria
Thanks all.
Looking around I found a push on fitting by aeroquip. This style will reduce the bulk and keep a simple look.
Tim
Downtown, Ca
Old 05-31-2015, 05:21 PM   #7
V8 Bob
V8 Bob's Avatar
Thanks all.
Aeroquip push-on, or "socketless", are my AN choice because their IDs are one of the largest, along with a very wide verity of styles to choose from.
Old 05-31-2015, 07:38 PM   #8
woodypecker
woodypecker's Avatar
I used 3/8 and my cold oil pressure is lower than hot pressure indicating to me that the hose should be a little bigger. Pressure is measured after oil is returned to block.
woodypecker is offline   Reply With Quote
