Old 05-27-2015, 09:48 AM   #1
Eighty
Eighty's Avatar
Default 1929 model a ignition switch
Need instruction on the removal of key cylinder from switch. Switch is dissembled from housing, but unable to remove cylinder. Thanks in advance!
Eighty is offline   Reply With Quote
Old 05-27-2015, 10:02 PM   #2
brito36
Default Re: 1929 model a ignition switch
A recent issue of the Model A News had a detailed article on pop out switch restoration. It should be able to help you out.
brito36 is offline   Reply With Quote
Old 05-27-2015, 10:11 PM   #3
mrtexas
mrtexas's Avatar
You will need the key.
mrtexas is offline   Reply With Quote
Old 05-27-2015, 10:42 PM   #4
MikeK
MikeK's Avatar
If you don't have a key put a little clockwise tension on the cylinder and rake it. Those flat plate cylinders open real easy that way. You can use a little flat blade screwdriver for the tension and a bent up paperclip as the rake. A locksmith could do it in less than a minute with a set like this:
MikeK is offline   Reply With Quote
