Old 05-19-2015, 09:04 AM   #1
CA Victoria
CA Victoria's Avatar
Default 8rt Fan Blade Options?
I have a stock 6 blade aluminum fan fitted to the stock 8 bolt hub assembly on my 8rt engine. Are/were there other fan blades offered for this configuration?
The exploded view in the F1 manual shows a 4 blade fan on the 8 bolt hub....
Or have other assemblies been adapted to fit this application with 3 or 4 blades?
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 05-19-2015, 09:07 AM   #2
JSeery
JSeery's Avatar
Default Re: 8rt Fan Blade Options?
What are you wanting to do, change it? I would think the 6 blade would be the best option.
Old 05-19-2015, 10:54 AM   #3
rotorwrench
rotorwrench's Avatar
The 6-blade may have been for larger trucks. Many of the fan parts are interchangeable between F series trucks. I know most of them used the same radiators & shrouds.
Old 05-19-2015, 11:01 AM   #4
cobra5laddict
as i understand the 6 blade fans were used on F5 and larger trucks. My F1 project came with a 6 blade when i got it. i plan on running it once i am ready, it cant hurt to have the extra airflow.
cobra5laddict is offline   Reply With Quote
Old 05-19-2015, 11:44 AM   #5
Barry-ct
Barry-ct's Avatar
4 blade was standard. I opted for the 6 blade for better airflow. THey are louder though....
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 05-19-2015, 11:52 AM   #6
CA Victoria
Ok, will BOL for a 4 blade fan.
Tim
Downtown, Ca
Old 05-19-2015, 01:05 PM   #7
36tbird
I have a 6 blade on my '36 and I do not notice it being louder. Man, it moves the air. I cannot get my 8ba with 180* thermostats to run over 178*.
36tbird is offline   Reply With Quote
Old 05-19-2015, 01:09 PM   #8
JSeery
JSeery's Avatar
Now there is a different problem!
Old 05-19-2015, 05:11 PM   #9
Ford Freak
I have a six blade unit on mine . Not loud at all .
Ford Freak is offline   Reply With Quote
