Old 05-06-2015, 05:32 PM   #1
jkassay
jkassay's Avatar
Default Rear Axle end play
While checking the breaks on my 30 coupe I noticed that the passenger side rear has a noticeable about of end play (about an 1/16). Grabbing the wheel and pulling and pushing produces a noticeable clack. Drivers side is OK.
I tried looking in the various repair manuals, but couldn't see any detail. Are there trust washers in the differential that controls this?
Everything at the drum/hub end seems to be OK. There is one shim installed on the taper, and I can't see how that would control the end play. Hub bearings look OK, and the axle nut is torqued properly.
Any suggestions?
jkassay is offline   Reply With Quote
Old 05-06-2015, 05:42 PM   #2
jkassay
jkassay's Avatar
Default Re: Rear Axle end play
Did a search for axle end play before, but spelled axle as "axel" no wonder I didn't find too much, lol.
Still not comfortable with what I have found, don't know if I should be worried?
Old 05-06-2015, 07:16 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
You might have some wear on the carrier thrust faces in the rear end, but at 1/16" I wouldn't worry about it unless the rear end needed to come apart for other repairs.
Too bad you aren't closer. I have a complete spare rear end.
Old 05-06-2015, 08:08 PM   #4
Mitch//pa
as Tom said your cool
Old 05-06-2015, 10:36 PM   #5
SeaSlugs
SeaSlugs's Avatar
yea, dont grab the wheel on a modern pickup, has about 1/16" play as normal haha.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
