Old 05-02-2015, 06:52 AM   #1
Steve Plucker
Default Tool for attaching rivet to Deck Door...
I got the flathead countersunk rivets to use to attach the upper left and right Deck Door brackets to the Deck Door for trunk usage.
Besides a special punch with a hollowed out area to form the upset of the flat head countersunk rivet, what other kind of tool would one think of to use to form the upset?
Thanks.
Pluck
Old 05-02-2015, 09:01 AM   #2
JTW
JTW's Avatar
Default Re: Tool for attaching rivet to Deck Door...
Air hammer with the same tool to fit it. Make sure the rivet is the right length sticking out, usually 1 1/2 time diameter. Bucking bar to fit on the back side. The aircraft industry has a lot of interesting rivet tools that they use, you might want to check that out also.
Driving old Fords since 1947
JTW is offline   Reply With Quote
Old 05-02-2015, 12:56 PM   #3
d.j. moordigian
d.j. moordigian's Avatar
Thanks.
Pluck
Steve,
Is this what your after ?
d.j. moordigian is offline   Reply With Quote
