Old 04-30-2015, 10:44 AM   #1
HotRodmicky
HotRodmicky's Avatar
Default Difference between 8ba and 59ab flywheel
Hi,
I have an aluminum 8ba flywheel that i want to use on my 59ab engine.
Is there an offset with the starter ring?
Beeing from Germany , swapping to correct 59ab is not easy .....
Is possible or WAY to much trouble?
HotRodmicky is offline   Reply With Quote
Old 04-30-2015, 11:02 AM   #2
Bruce Lancaster
Default Re: Difference between 8ba and 59ab flywheel
Ol Ron's book gives a dimensional method of sorting them...essentially measuring distance from flange on one side to friction surface on the other. I've always had the right sort lying around so never worried about it.
I believe there is some offset, fractional, to ring gear. Actual interference problems I have heard of involve early wheel on late motor, the opposite of what you are wanting to do.
I don't see why the different width of the gear would matter.
Empirical approach...bolt it on and see if engine can be rotated. Add starter and see if it engages and disengages when fed electricity. I think the late ring gear will be slightly forward of early gear proper position.
Bruce Lancaster is offline   Reply With Quote
Old 04-30-2015, 12:29 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
Here's a pic of the difference! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 04-30-2015, 12:47 PM   #4
Bruce Lancaster
But note also the difference between gears is reduced a bit by deeper flange there. You need to do something like setting the flanges on a known size block and measuring thus to friction surface and to ring gear location so you can get truly comparable results. The practical questions are whether the gear winds up in the working travel of the starter drive and whether the thing clears the block and then whether main surface is not too far off...
I actually measured a bunch of this when I got hold of Ron's book years ago, but lost interest because I had a decent supply of properly matched flywheels. I blocked up the wheels on their crank flanges with sockets that were 1" long to make the arithmetic simple...
Old 04-30-2015, 01:46 PM   #5
19Fordy
19Fordy's Avatar
HotRodmicky, I know they are expensive, but save yourself a lot of grief and use a 49-53 Alum. flywheel.
Old 04-30-2015, 01:58 PM   #6
JSeery
JSeery's Avatar
Other way around I think, he has an 8ba and needs a 59a.
Old 04-30-2015, 02:06 PM   #7
V8 Bob
V8 Bob's Avatar
Another option is a new steel flywheel from Centerforce that is much cheaper than aluminum, is about 10 lbs lighter than stock, come multi-drilled for Long/B&B/diaphragm and are available for both early and late flatheads.
V8 Bob is offline   Reply With Quote
Old 04-30-2015, 03:23 PM   #8
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Years ago I had a 58AB on the engine stand, I installed a 59 wheel and measured from the back of the block to the ring gear, and then I installed an 8BA wheel and the gear is about 3/8in. (I think), back further than the 59 wheel, the problem is the starter drive won't go back far enough to disengage the gear. NOW, if you going the other way around, putting a 59 wheel on an 8BA block you could put a spacer between the wheel and the crank. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 04-30-2015, 03:55 PM   #9
jimTN
Did the same thing Walt and engine was already back in my 40 when I found out..... About as bad as putting a throw out fork in with a soft bolt instead of a hardend pin!
jimTN is offline   Reply With Quote
Old 04-30-2015, 04:33 PM   #10
36tbird
Not sure, but if the starter is the problem, don't the small, aftermarket starters work with either?
36tbird is offline   Reply With Quote
Old 05-01-2015, 08:44 AM   #11
Bruce Lancaster
Starters interchange '32-53 on standard shift 221--255 enines. The difference must be made up in the location of starter mount so the starter drive movement range is in the right place.
Old 05-01-2015, 11:28 AM   #12
JSeery
JSeery's Avatar
Bruce, did you mean 32-53?
