Old 04-18-2015, 03:04 AM   #1
GT66PONY
Default 5/16 Bolts
What is the function of the bump on the splash pan bolts ? can you get new ones? should I use new ones or the old ones?
Thanks Gary
GT66PONY is offline   Reply With Quote
Old 04-18-2015, 04:53 AM   #2
RonC
RonC's Avatar
Default Re: 5/16 Bolts
www.fordscript.com
http://www.fordscript.com/ford_bolts...ogs/modelA.pdf
RonC is offline   Reply With Quote
Old 04-18-2015, 08:05 AM   #3
portside
I believe the bump holds the bolts in place until you lay the running boards in place. I would use the old bolts if they are in good condition.
portside is offline   Reply With Quote
