Old 04-14-2015, 08:54 PM   #1
ecobbs01
Default Model A's in the Mountains
Howdy everyone,
. I'm thinking about getting a Ford Model A one of these days, and I was wondering, with all the steep hills and whatnot around us here in the Ozark mountains, how steep an incline a stock model A could handle. And whether or not they could handle steep inclines that are unpaved. Thanks for any input y'all can give me, it is greatly appreciated! Godspeed.
ecobbs01 is offline   Reply With Quote
Old 04-14-2015, 09:00 PM   #2
SteveB31
SteveB31's Avatar
Default Re: Model A's in the Mountains
Out here in Colorado , where are mountains are 14,000 feet, and our mountain passes are 11,000 plus feet, we drive the Model A's all the time. You will not have any problems in your little mountains. These cars are made for them. Geared low and lots of torque.
Steve Becker
Berts Model A Center
SteveB31 is offline   Reply With Quote
Old 04-14-2015, 09:03 PM   #3
Fred K-OR
Fred K-OR's Avatar
I think Model A's in the days they were used for everyday use (1930's) they handled these kinds of roads and ones much more of a challenge, very well. But now days you need to be concerned about modern drivers and freeways that may be the challenge.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 04-14-2015, 09:03 PM   #4
ecobbs01
thanks for the input! It'll for sure come in handy.
Old 04-14-2015, 09:39 PM   #5
Gyrodoc
Gyrodoc's Avatar
I used to have a house in Forsyth, Mo. Model A can handle those hills just fine.
Gyrodoc is offline   Reply With Quote
Old 04-14-2015, 09:40 PM   #6
glenn in camino
glenn in camino's Avatar
Get an overdrive so you will have 2n gear over.
glenn in camino is offline   Reply With Quote
Old 04-14-2015, 09:53 PM   #7
vern hodgson
Originally Posted by ecobbs01 View Post
Howdy everyone,
I attended an off road jeep rally
With my Tudor, I could go almost any where the jeeps could go except for super steep, rooted and rocky cat tracks.
vern hodgson is offline   Reply With Quote
Old 04-14-2015, 11:07 PM   #8
whirnot
whirnot's Avatar
And adding to what Steve said, we recently took 15 model A's on tour, climbing 7 to 10 % grades. Not a problem in the group.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 04-14-2015, 11:50 PM   #9
pat in Santa Cruz
pat in Santa Cruz's Avatar
I live in the mountains, although nothing like the Rockys. An overdrive will give you the gear you need between 2nd and high. I use it all the time.
pat in Santa Cruz is offline   Reply With Quote
Old 04-15-2015, 01:26 AM   #10
montanafordman
montanafordman's Avatar
I've driven mine on some fairly steep grades, and like many have said hills are no problem, speed and traffic are the issues because you cant pull a steeper grade in 3rd without lugging it, and 2nd is pretty low so your RPMs are screaming if you want to keep up - this is where an overdrive really shines being able to split the gap between 2nd and 3rd. I almost equate this as much as an asset as being able to go a few mph's faster in 3rd on more level ground.
Aaron in T̶a̶c̶o̶m̶a̶ Meridian, Idaho
(although still a Montana hillbilly at heart )
1931 Coupe
1931 slant window sedan
montanafordman is offline   Reply With Quote
Old 04-15-2015, 07:17 AM   #11
Gold Digger
I live in northern Arkansas and never have had any problems.
Gold Digger is offline   Reply With Quote
Old 04-15-2015, 07:17 AM   #12
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Hope you do get an A. You will have a ton of fun with it. There is nothing like an A.
Jacksonlll is offline   Reply With Quote
Old 04-15-2015, 08:43 AM   #13
mshmodela
mshmodela's Avatar
Go for it as soon as you can, Model A's are great.
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 04-15-2015, 09:17 AM   #14
C26Pinelake
Steve Becker
Mountains to some are hills to others ( lol ) ! Wayne
C26Pinelake is offline   Reply With Quote
Old 04-16-2015, 07:33 AM   #15
Cracker39
Cracker39's Avatar
Climbing hills wouldn't concern me, but having experienced brake fade with drum brakes certainly does. This was a special problem with the earlier automatic transmissions when pulling a trailer. How does a Model A do coming downhill in third gear? What speed will it hold? Do you frequently use second on long grades - or never? There are drives I'd like to make if I was a bit more comfortable with the "downhill" part.
Cracker39 is offline   Reply With Quote
Old 04-16-2015, 08:02 AM   #16
Tom Wesenberg
Tom Wesenberg's Avatar
I know the feeling. I was driving someone's Model A in St. Paul and when decending a steep hill the brake fade was so bad the pedal went to the floor and I had to glide through a red light at the bottom of the hill. Sure glad no one was coming.
You can hold your own in second gear, but there will be modern drivers ready to run you over.
Old 04-16-2015, 09:01 AM   #17
larrys40
Steve Becker
Well said Steve . I live here in Missouri but have traveled in my Tudor out to the high country tours since the 80's , and have had extended tours out there following, touring over cottonwood, Cumberland, over to tincup, pitkin, tr San Juan range over to ouray, etc and many other mountain passes out there, some if them hard gravel with snow still present in June .
A well restored prepped Model A in good shape shouldn't have any problems . I have also driven it up Pikes Peak and when the use the infrared on the way down to check your brakes mine weren't even warm. Use your gears properly both up and down grades and it will do fine
Ozark mountains really aren't much for an A .
Larry Shepard
larrys40 is offline   Reply With Quote
Old 04-16-2015, 09:31 AM   #18
CarlG
CarlG's Avatar
My dad taught me that "if you use second gear going up the mountain, you need to use second gear going down the mountain."
Even here in Alaska, I rarely have to downshift (except to take it out of overdrive)
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 04-16-2015, 09:34 AM   #19
Cracker39
Cracker39's Avatar
Larry Shepard
Being familiar with Pike's Peak, as many of us are, did you use second all the way down, and how often did you have to brake?
Old 04-16-2015, 10:04 AM   #20
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Oatman, Arizona, on OLD Highway 66, in Western Arizona, is at the crest of the Black Mountains. STEEP, CONSTANT switchbacks! You're in SECOND gear, each time you come to a sharp switchback, it's back to LOW gear, then back to SECOND gear!! Downgrade is ALL SECOND gear, with your hand on the shifter, to prevent a possible JUMP OUT!!
Google, Oatman, Arizona, TRICK place, lots of movies shot there & Donkeys roam the street.
Bill W.
"THE ASSISTANT GURU OF STUFF"
