Old 04-13-2015, 05:51 PM   #1
corvette8n
corvette8n's Avatar
Default Is this really true
Found this on a Craigslist ad, I can't verify this info using the Early Ford V8 book, is this guy pulling my leg.
The block is a 1946 "F". It looks like a 59AB, but it has a factory 4 inch stroke. This is not the Mercury crank, but a ford factory crank......very hard to find. Not only that, the block was factory ported.
http://bismarck.craigslist.org/cto/4942307754.html
Old 04-13-2015, 05:56 PM   #2
Kahuna
Kahuna's Avatar
Default Re: Is this really true
Pulling your leg, I think
Kahuna is offline   Reply With Quote
Old 04-13-2015, 06:09 PM   #3
deuce_roadster
deuce_roadster's Avatar
While the car looks to be worth the asking price, the info on the engine is very suspect. Probably the engine was rebuilt by someone who did the porting work on it and changed to a merc crank (if indeed it has a 4" crank and was ported). I would ask the current owner where he got his info regarding the engine. Did he see it apart?
Old 04-13-2015, 06:16 PM   #4
Scott H in Wheaton
Scott H in Wheaton's Avatar
Maybe that's the engine Ford has been looking for in the last 70 years...you know the story, its a factory experimental and was never supposed to be sold, it has a carburetor that gets 100mpg and the oil industry and automakers don't want the public to know because it would kill profits, etc etc
Making a one-off engine with a 4" crank and spending the time to at the factory to port the engine just doesn't jive with assembly line production methods used in the 40's.
Is he claiming it was something done for the war effort?
Mac Van Pelt might know something if anything is available on it.
Scott H in Wheaton is offline   Reply With Quote
Old 04-13-2015, 06:19 PM   #5
JSeery
JSeery's Avatar
He may be referring to factor relived. There are a lot of factor relived blocks, but don't thing I have heard of the factor ported block.
Old 04-13-2015, 06:24 PM   #6
Scott H in Wheaton
Is it a French Flathead?
Old 04-13-2015, 06:40 PM   #7
Bruce Lancaster
Yessir, the fabled F motor, handbuilt in the toolmaking department especially for Harry Bennett's fleet of speed cars that shuttled Henry to his mistresses' houses and transported union organizers to their free company sponsored diving lessons in Lake Huron...
They were all supposed to have been destroyed at Henry's death...obviously one survived!
Must be worth millions! Of something!
Bruce Lancaster is offline   Reply With Quote
Old 04-13-2015, 06:50 PM   #8
51 MERC-CT
51 MERC-CT's Avatar
Very possible that it indeed may be a factory Ford crank that was stroked but not by the factory.
Old 04-13-2015, 07:10 PM   #9
B-O-B
B-O-B's Avatar
My roadster has an F block & I thought it might be a 4" stroke but have not pulled the heads to verify. Sure does have some rough casting heads. It also came from the midwest. Revs up pretty quick also. My thought is if it ain't broke don't break it. so I ain't pulling a head to find out. Some where someone suggested an F block was a foreign import ,like Argentina.
B-O-B is offline   Reply With Quote
Old 04-13-2015, 07:37 PM   #10
Bruce Lancaster
Argentine cars were built from USA parts...there was no factory, just assembly in flathead days. I think in 1934 flathead engines were built only at Rouge plant and in Canada, which between then supplied all assembly plants everywhere.
Before the Merc 4" crank was released in '49, strokers were scarce and expensive.
'39-48 Merc cranks could be offset ground to Ford rod size for a pitiful 1/8" increase, or given a shaky larger larger increase with welding or metal spraying. Risky and expensive. Some entirely special cranks were made, off the financial map for most humans.
Old 04-13-2015, 07:56 PM   #11
Tinker
Tinker's Avatar
Isn't a merc 4" crank still a ford crank? It's not a Chevy crank anyway. No pictures of the famous engine in the add? Strange...
It'd be interesting to check out anyway. Grill looks repop too. Maybe not.
Bob curiously for the price of a gasket would have me pulling that head...
Old 04-13-2015, 08:13 PM   #12
tubman
tubman's Avatar
Bruce Lancaster is right. That was the same group that produced the "factory" McCullogh blown F1 that they were hawking a few years ago. Guy selling it swore up and down that it came from the factory that way.
Old 04-13-2015, 08:23 PM   #13
Bruce Lancaster
...the price of a gasket would have me pulling that head...
You'd need to pull the pan and a rod cap for meaningful search of the almost certainly false claim...he seems to be calling it an early engine with something predating the '49 merc!
It would have to be an unaltered crank in early style, one hole per throw and no cleanouts, to be anything unusual. If it has a merc crank, it is simply a normal hop-up performed after 1949, not what he seems to be claiming. I'm not saying Ford didn't do undocumented private tests of unusual experiments, but if one turns up...it needs more than unexplained mystery codes and a unique crank that so far only exists in unsupported verbiage...
Old 04-13-2015, 08:46 PM   #14
Tinker
Tinker's Avatar
Hey it's the Internet it must be true.
Old 04-13-2015, 09:44 PM   #15
B-O-B
B-O-B's Avatar
Tinker:
Runs good & that's good enough for me.
Bruce:
So what does the l* 3152*
l8F
stand for? the two vertical (l) indicate the front of the block & the 8F is underneath the numbers.
8F
S**** I tried to line up the 8F under the numbers but it keeps going to the beginning of the next line.
Old 04-13-2015, 11:18 PM   #16
Mike B
I'm not nowhere a FH expert, tis why I come here to the barn...but, makes me think hard and long on the ad's description, the ad owner has done "30 FLATHEADS", or had 30...regardless. then mentions an obcsure engine, no one..even Bruce, has heard of...then goe's on to say rust free, etc...
Yes, nice looking car, but is it?
Mike B is offline   Reply With Quote
Old 04-14-2015, 08:01 AM   #17
Mike51Merc
Mike51Merc's Avatar
If the guy has done more than 30 flatheads, he ought to be a member here (or is he?).
Mike51Merc is offline   Reply With Quote
Old 04-14-2015, 08:56 AM   #18
ricklove
ricklove's Avatar
Bottom line; IMHO it appears to be a reasonable price if the car is as nice as the pics present and he claims (always inspect before you buy). The "fluff" about the engine could be what he was told and is passing it along as gospel. If I was a potential buyer; I'd probably be making a trip to Rapid City to check it out personally.
ricklove is offline   Reply With Quote
Old 04-14-2015, 09:29 AM   #19
Bob C
Have to be careful there, he didn't say it was rust free
he said "It has no rust through anywhere"
Bob
Old 04-14-2015, 09:35 AM   #20
Bruce Lancaster
Those numbers are way too low to be serials and aren't right for Ford engine part numbers or models...as a flying guess, they may be an engine number stamped on by a rebuilder to identify the engine as one he did.
The thing looks like a neat car with a running flathead...that's plenty good enough. The top secret unknown goodies, though...
