Old 04-13-2015, 11:04 AM   #1
bikemaniac
Smile Throttle pedal not convenient for accelerating
Hi,
When driving a modern car I can keep the heel of my foot in the floor and bend my foot forwards for acceleration. The linkage is made in such a way that a normal sized foot naturally follows the travel of the pedal.
In a model A I feel I can only use the throttle pedal if I lift my entire foot from the floor in order to press the pedal. It is quite annoying, especially if you need to do a lot of driving in town. My leg never rests. This is due to the fact that the pedal does not follow the natural motion of the heel rested foot. There is a lot of friction between the foot and the throttle pedal and thus I am not in a "smooth" control of the pedal.
You probably all know what I mean. Am I driving the model A wrongly, do I have to bend something, is there an upgrade kit ... or something else?
Lucas
bikemaniac is offline   Reply With Quote
Old 04-13-2015, 11:10 AM   #2
Jim Brierley
Default Re: Throttle pedal not convenient for accelerating
Does your A have the stock foot-rest mounted next to the throttle?
Jim Brierley is offline   Reply With Quote
Old 04-13-2015, 11:14 AM   #3
John Duden
John Duden's Avatar
Use the hand throttle
John Duden is offline   Reply With Quote
Old 04-13-2015, 11:16 AM   #4
harleytoprock
If for some reason the pedal is too high from the floor board, your foot is not at a comfortable angle. Try playing around with the linkage length but make sure you get full throttle before the pedal bottoms on the floor. Worked for me.
harleytoprock is offline   Reply With Quote
Old 04-13-2015, 11:17 AM   #5
Kohnke Rebabbitting
You put your foot on the foot rest, and then role your foot to the left for the throttle, easy.
Herm.
Kohnke Rebabbitting is offline   Reply With Quote
Old 04-13-2015, 11:20 AM   #6
Tacoma Bob
Tacoma Bob's Avatar
I struggle with this as well. After many years of driving these cars what works best (although I'm still training myself) is to rest my foot on the foot rest with my heal on the floor and roll my foot to the left.
Tacoma Bob is offline   Reply With Quote
Old 04-13-2015, 11:23 AM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Yes, your foot and the throttle do swing in opposite arcs, but I have never found it to be a problem. You could fasten a thin piece of steel plate to a hinge and screw the hinge to the wood floorboard, then both would swing in the same arc. Put a little grease where the round pedal hits the steel plate.
Old 04-13-2015, 11:33 AM   #8
CarlG
CarlG's Avatar
You might try one of these that the vendors offer:
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 04-13-2015, 12:12 PM   #9
Bob Johnson
Bob Johnson's Avatar
I also roll my foot to the left while resting it on the foot rest. See link below for video clip of how I do it. Let me know if the link does not work.
Bob
Video clip link
Bob Johnson is offline   Reply With Quote
Old 04-13-2015, 12:24 PM   #10
ModelAMike1930
ModelAMike1930's Avatar
I have 2 of those aftermarket gas petals they work great..
ModelAMike1930 is offline   Reply With Quote
Old 04-13-2015, 12:29 PM   #11
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I simply screw off the rest, works for me.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 04-13-2015, 01:20 PM   #12
hardtimes
hardtimes's Avatar
Hey Lucas,
I found that removing the 'foot rest', and installing a metal plate....keeps the pedal rod in center of hole thru floorboard and works more like other cars I drive.
You've experienced a 'situation/problem', IMO, that a lot experience. The foot rest is very uncomfortable, especially if you have leg problems..rolling leg/foot to left.
hardtimes is offline   Reply With Quote
Old 04-13-2015, 09:01 PM   #13
Paul
Paul's Avatar
wear hard leather sole shoes,
modern shoes are far too soft and pliable
it's all good
Paul is offline   Reply With Quote
Old 04-13-2015, 09:22 PM   #14
Fred K-OR
Fred K-OR's Avatar
Herm.
Do the same and works OK for me also. But need to maybe adjust the foot rest to the correct height.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 04-13-2015, 09:31 PM   #15
Willie Krash
Willie Krash's Avatar
I find the original Ford design very comfortable. All the angles are just right, but that''s just me.
Mike Stitt
"A business that make nothing but money is a poor business."
-Henry Ford
Willie Krash is offline   Reply With Quote
Old 04-13-2015, 10:01 PM   #16
Marco Tahtaras
Marco Tahtaras's Avatar
Yep, just adjust the rest to a comfortable height that works and the heel never leaves the floor. Living on the west coast of California (and not going into an office anymore) I wear flip-flops 90% of the time. I quickly downshift going into all right turns and many left turns. Never an issue!
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 04-14-2015, 01:00 AM   #17
BILL WILLIAMSON
A friend made a nifty throttle pedal by putting a hinge on a wooden sole, from sumbody's??? SANDLE!!
Bill W.
Old 04-14-2015, 09:31 AM   #18
V4F
V4F's Avatar
all ideas are good , but I changed to a cable & swing pedal & it is much easier & consistent .
V4f
V4F is offline   Reply With Quote
Old 04-14-2015, 09:52 AM   #19
CarlG
CarlG's Avatar
Do you have a picture or diagram of how you accomplished this?
Alaskan A's
