Old 04-06-2015, 09:16 PM   #1
boo
Default what oil for columbia rear
when ordering parts today, i wanted oil for my 48 transmission and columbia rear. the order taker said that the trans oil they sell was not for a columbia rear, they didn't know what to use. what kind of oil should i use for the columbia and trans????
boo is offline   Reply With Quote
Old 04-07-2015, 09:33 AM   #2
rotorwrench
rotorwrench's Avatar
Default Re: what oil for columbia rear
Rear axle can use any straight grade SAE 90 or SAE 140 GL-4 or GL-5 lubricant. They can also use any multi-viscosity lube. The transmissions use GL-4. SAE 90 in cooler climates and SAE 140 in warmer climates. Sta-lube GL-4 can be purchased from a local NAPA dealer in straight grades. You can also use it in the Columbia 2-speed axle.
http://www.fordbarn.com/forum/showth...t=columbia+oil
rotorwrench is online now   Reply With Quote
Old 04-07-2015, 01:57 PM   #3
G.M.
I have 10 working Columbia's I use gear oil and molly grease. The gears will mix it like a blender. I use enough grease to make it about like honey. Several hundred thousand
miles in mostly warm weather, no problems. Marvel Mystery oil in the vacume shifter cylinder for smooth solid shifting. G.M.
www.fordcollector.com
Old 04-07-2015, 02:53 PM   #4
merc40
g.m. how do I put m.m.o. in my vacume shifter ? had hard shifting the last 2 trips out. have had know problems in 12 years but I love that rear end. like your posts .reguards to you. dick t.
merc40 is offline   Reply With Quote
Old 04-07-2015, 07:23 PM   #5
G.M.
Remove both hoses, fill a small squeeze bottle with MMO, take an air hose and with only a few pounds of air blow in on of the cylinder tubes. The air will shift the cylinder away from the air, give the side you blew the air in a good shot of MMO. Blow air in the opposite tube then the MMO. Do this several times so the leather gets good and soaked. G.M.
Old 04-07-2015, 08:21 PM   #6
49fordv8f4
49fordv8f4's Avatar
Would GL-5 attack the bronze washers in the Columbia?
Mark
49fordv8f4 is offline   Reply With Quote
Old 04-08-2015, 07:56 AM   #7
merc40
thanks g.m. reguards dick t.
Old 09-12-2024, 11:17 AM   #8
Jim C.
Mark
Many people think GL-5 is not good for the Columbia. See July / August 2024 V-8 Times magazine page 105. Jim C.
Jim C. is offline   Reply With Quote
Old 09-13-2024, 11:17 AM   #9
Terry,OH
Terry,OH's Avatar
140W, NAPA # SL 24238. There is a procedure to fill correctly. Fill to the Columbia filler plug, run for 10 min on jack stands with Columbia in overdrive, then refill to the Columbia fill plug.
Old 09-13-2024, 02:57 PM   #10
Bruce_MO
John Connelly, who did a lot of work on my axle and furnished many of his parts for it, told me to use 90-140W gear lube, and said “there’s not enough bronze in a Columbia to worry about GL-5 issues”
Bruce_MO is offline   Reply With Quote
