Old 03-24-2015, 03:33 PM   #1
AnthonyG
AnthonyG's Avatar
Default '50 F2 price?
Looking at a 50 F2. Seems to me they are worth some what less than the F1? This one the guys asking $6500. Add says runs and drives good, new brakes, needs minor cosmetic restoration. See attached? Too much, just right?
Nomad
AnthonyG is offline   Reply With Quote
Old 03-24-2015, 03:55 PM   #2
30-9
Default Re: '50 F2 price?
From pic and description seem worth 6500
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 03-24-2015, 03:58 PM   #3
bart78
bart78's Avatar
How long has it been for sale?
bart78 is offline   Reply With Quote
Old 03-24-2015, 04:12 PM   #4
AnthonyG
AnthonyG's Avatar
Listed for about a week
Nomad
Old 03-24-2015, 04:12 PM   #5
AnthonyG
AnthonyG's Avatar
I'm going to look at it on thurs morning.
Nomad
Old 03-24-2015, 04:22 PM   #6
30-9
Good luck lets us know how it turns out
Thanks - 30-9
1939, 1940
Old 03-24-2015, 04:28 PM   #7
Fibber Mcgee
Fibber Mcgee's Avatar
If it runs well and has very little rust ,I'd say it's definitely worth it. The F2s maybe less popular but they are also less common so it's a matter of taste. If you like it I would make an offer of say $5000 and see what happens.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
Old 03-24-2015, 04:36 PM   #8
AnthonyG
AnthonyG's Avatar
Yep, was thinking $5K to me my target.
Nomad
Old 03-24-2015, 04:38 PM   #9
Gumpy
Gumpy's Avatar
I think 5k would be a good offer
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford
Gumpy is offline   Reply With Quote
Old 03-24-2015, 04:41 PM   #10
AnthonyG
AnthonyG's Avatar
Is it common to remove a couple of leafs to make the ride a little softer, or is it possible to use F1 springs?
Nomad
Old 03-24-2015, 04:48 PM   #11
glennsanders
glennsanders's Avatar
I agree looks solid,the f2s have high rear gear.Going to back Rd truck.It all depends on what you are going to be doing and were you want to drive it.Check cab and sheet metal for rust and holes.A rust free running f2 no smoke 3500-6000 It all about condition. Looks good from here,Good luck need any parts call me 301 514-5017
glennsanders is offline   Reply With Quote
Old 03-24-2015, 05:05 PM   #12
AnthonyG
AnthonyG's Avatar
Other than the obvious ( suspension ) are they that much different than the F1's. I think they were only available with a long bed but F1 were available with the long bed. Assuming the chassis is heavier but is the cab / bed any different? Booked up a little on F1's but this came up and looked interesting. Guess I gotta go back to school?
Nomad
Old 03-24-2015, 06:28 PM   #13
rotorwrench
rotorwrench's Avatar
F2s have heavier springs, bigger brakes, and a heavier rear axle among a few other differences. The F2 & F3 are both a bit harder to source the parts that are common to them only. You can haul a lot more and trailer a bigger package than the F1 for sure but they are more utilitarian and therefore less popular than the F1. We had an F3 when I was a kid and it rode like a lumber wagon but I loved the damn thing. I learned more about driving in that old truck than any other single vehicle when I was growing up. We could haul a 1500 lb bull in the bed with no problem (we custom built a stock rack to fit into the bed). We also had a big water tank for it when the windmill was on the fritz.
Old 03-24-2015, 06:56 PM   #14
AnthonyG
AnthonyG's Avatar
Probably sound like a dummy but can I put the F1 springs on the F2 to ease up the ride? Or, do I need to pull the springs apart and remove a couple of leafs. If so how many front and rear makes it a reasonable ride?
Nomad
Old 03-24-2015, 08:48 PM   #15
Ken Crans
Ken Crans's Avatar
Offer him 5 grand. Leave the main and the first leaf on and every one afterwards.
Ken Crans is offline   Reply With Quote
Old 03-24-2015, 09:06 PM   #16
billwill
Front springs of F! will fit the f2You also have bear for a rear end gear of 4 86 45 mile per hour top speed Good luck
billwill is offline   Reply With Quote
Old 03-24-2015, 09:29 PM   #17
slowforty
If it has the Four-speed transmission,You will graduate from the College of Double-Clutching.
slowforty is offline   Reply With Quote
Old 03-24-2015, 09:49 PM   #18
AnthonyG
AnthonyG's Avatar
Did the '50 have an open drive shaft or still have a closed torque tube?
Nomad
Old 03-24-2015, 10:20 PM   #19
Mike B
Open drive started in '42 for the PU's, so yes, open drive.
Mike B is offline   Reply With Quote
Old 03-25-2015, 12:17 AM   #20
expavr
expavr's Avatar
Chuck Manzione http://www.chuckstrucksllc.com/ sells a 4.11 gear set for the 3/4 and 1 ton trucks. They definitely made a difference with my Tonner's driveability. In my opinion if you're looking for a truck that can do some serious hauling and still get appreciated by onlookers, you can't beat the big trucks. Assuming the photos to be representative of its overall condition that F2 looks to be a keeper to me.
expavr is offline   Reply With Quote
