Old 03-21-2015, 12:57 PM   #1
Shadetree
Shadetree's Avatar
Default F1 Radiator Fan Shroud
Are the radiator fan shrouds on the `48 thru `52 pickups the same for six cylinder and V-8's?
Son, you will never blow an engine up in high gear.
Shadetree is offline   Reply With Quote
Old 03-21-2015, 01:32 PM   #2
cmbrucew
cmbrucew's Avatar
Default Re: F1 Radiator Fan Shroud
Shade
No, but could be made to work.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 03-21-2015, 09:21 PM   #3
Shadetree
Shadetree's Avatar
Originally Posted by cmbrucew View Post
Shade
Bruce
Bruce,
Is it pretty simple like drilling some extra holes?
Thanks
Old 03-21-2015, 10:23 PM   #4
Ross F-1
Ross F-1's Avatar
The V8 has two reliefs across the bottom for the radiator hoses, the six only has one. The fan on the six is right on the water pump, so I'm thinking it isn't centered on the radiator like the V8.
edit: looking at pictures of the 6, the fan does look to be centered
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 03-21-2015, 10:26 PM   #5
gearhead1952
gearhead1952's Avatar
Probably easier to put a v8 shroud on a 6 than the other way around. The v8 radiator has 4 hose connections and the six only has two. The v8 shroud is dimpled at the bottom for the two hoses. Not sure if the fans are located in the same spot between the two engines. There is a v8 shroud on ebay now although a bit pricey.
http://www.ebay.com/itm/1948-1949-19...-/121601304838
gearhead1952 is offline   Reply With Quote
