Old 03-20-2015, 11:14 AM   #1
1930 Cabriolet
Default Install a V8 Into a Model A
How to install A flathead V8 into a Ford Model A?
Please respond email or post reply.
[email protected]
1930 Cabriolet is offline   Reply With Quote
Old 03-20-2015, 11:38 AM   #2
Scott H in Wheaton
Scott H in Wheaton's Avatar
Default Re: Install a V8 Into a Model A
I would use an engine hoist
Scott H in Wheaton is offline   Reply With Quote
Old 03-20-2015, 11:45 AM   #3
Henry/Kokomo
Henry/Kokomo's Avatar
Lots of things must be considered. If you could describe your project in more detail or ask some more specific questions, I'm sure you'd get appropriate answers. I'm also building an AV8 and would be glad to share what I know about it.
Regards
Henry
Henry/Kokomo is offline   Reply With Quote
Old 03-20-2015, 12:00 PM   #4
john in illinois
john in illinois's Avatar
As Henry said,it depends on what you want to do. I also am building one. A good start to see what is involved is the Bishop Tardel book.
http://www.amazon.com/Build-Traditio...+bishop+tardel
I would be glad to answer any questions.
John
john in illinois is offline   Reply With Quote
Old 03-20-2015, 12:10 PM   #5
Mart
Mart's Avatar
I could spend an hour telling you everything I know, but with such a short request for info I don't feel inclined to.
Give more details of what you have, what you want to do, what you know and what you are unsure of.
The tardel/bishop is a great place to start.
There are some build threads on the hamb too.
Put some effort in and start looking.
Mart.
Old 03-20-2015, 12:11 PM   #6
Charlie Stephens
[email protected]
Please don't request emailed replies, other people might want the information and it provides the opportunity for a large group to evaluate the correctness of the information. Another reason to use posts is that people will assume you already have been sent the answer and it is not worth their time (and answering your question will take time) and not waste their time writing a reply.
Charlie Stephens
Old 03-20-2015, 12:12 PM   #7
bart78
bart78's Avatar
Buy the Bishop Tardel book. That will get you started.
bart78 is offline   Reply With Quote
Old 03-20-2015, 05:39 PM   #8
Brendan
Brendan's Avatar
I have a 29 Roadster, I also have a good 37 motor. also I was going to use the A rear when the V8 finds its way in there. I was wondering if a guy could use Dennis Clings kit to use the A petals. the kit is made for putting a 39 trans in an A also I was thinking about fabing up a rear cross member.one thing I have to do is move the steering box forward. also I have to cut a little off the fire wall, there is a little section that the toe board sits on
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 03-20-2015, 05:40 PM   #9
Brendan
Brendan's Avatar
I wanted to use the kit for the 39 trans because I have juice brakes on my car
Old 03-20-2015, 05:46 PM   #10
Brendan
Brendan's Avatar
I tried this on for size, I have to get it back about in inch, that is why I need to trim the fire wall!
Old 03-20-2015, 05:48 PM   #11
39topless
Thumbs up Re: Install a V8 Into a Model A
Charlie Stephens
Excellent comment. This is a public forum for all the reasons you point out. Thank you
39topless is offline   Reply With Quote
Old 03-20-2015, 05:56 PM   #12
Mart
Mart's Avatar
Brendan, would a conversion to a 2 bolt crab dizzy help?
Old 03-20-2015, 06:00 PM   #13
32forddump
32forddump's Avatar
Now, thats going to be fun!
I know I can, I know I can http://www.flickr.com/photos/waltsprojects/
32forddump is offline   Reply With Quote
Old 03-20-2015, 06:07 PM   #14
Brendan
Brendan's Avatar
no, I just tried to stick this in for fun, I had to do some work on the banger. I needed to get the hole thing back about 1 to 1 and a half inch. this is all stuff I have been thinking about the block was hitting the firewall about where the intake is sitting on top of the block, I would have to trim the firewall a little bit
Old 03-21-2015, 07:07 AM   #15
PeterC
PeterC's Avatar
Too bad to mess up the fire wall - can you just switch the ignition to crab style or is clearance issue more than that?
PeterC is offline   Reply With Quote
Old 03-21-2015, 07:39 AM   #16
Ol' Ron
Ol' Ron's Avatar
The Tardel book is the best place to start.
Old 03-21-2015, 07:43 AM   #17
john in illinois
There are many things to determine engine location. steering box and header fit,firewall clearance,radiator clearance and wishbone distance if unsplit.
I ended up close to firewall. I am not using a stock fuel pump,so I am going to use an angled oil fill tube to clear.
Old 03-21-2015, 07:45 AM   #18
john in illinois
A little farther along., Header- steering box.
Old 03-21-2015, 07:55 AM   #19
Brendan
Brendan's Avatar
are you running the A rear end?
Old 03-21-2015, 07:56 AM   #20
jimTN
I saw one here locally that was unique in that the wishbones were split and engine dropped down lower in the frame so that it cleared the firewall. Years ago I had one and the firewall was cut to clear back of the engine and moved back. Stock steering did not get in the way. It had a 49-53 truck engine.
jimTN is offline   Reply With Quote
