Old 03-17-2015, 01:40 PM   #1
Willie Krash
Willie Krash's Avatar
Default Headlight Adjustment made easy
I was reading an old article by Walt Langill re headlights.
His adjustment of headlights is quite simple. Use a straight 2X4 and put across the lights and make them parallel to the 2x4. Make sure the car is level and use a carpenters spirit level on each headlight face and cocked them down until they are 1/2 bubble off of plumb or 1/2 bubble on the level.
That's it.
Now part two. Some time back I adjusted mine by the Ford book sort of..Blue tape on an old warehouse wall in the middle of the night, driving around and readjusted.
I grew tired of it all and just drove on dark roads and found the sweet spot. With my new Brattons reflectors I was quite amazed. Not bad at all.
So I thought let's see if the article conforms to my sweet spot. Well the two headlights were within 1/4" of being parallel (something I did knowingly) and both lights were dead on....1/2 bubble off plumb. So pun intended that was my after the fact blind test.
H/T to Marshall Lewis for the idea and thank you Rick Black for the article.
I did do a quick search so if this has been addressed sorry, but it still is good info.
Mike Stitt
"A business that make nothing but money is a poor business."
-Henry Ford
Willie Krash is offline   Reply With Quote
Old 03-17-2015, 02:27 PM   #2
CYB4
CYB4's Avatar
Default Re: Headlight Adjustment made easy
Thanks, I will check it out next weekend.
Best regards
Chris
1930 Ford A Std. Tudor
CYB4 is offline   Reply With Quote
Old 03-17-2015, 03:00 PM   #3
CarlG
CarlG's Avatar
I've used this same approach, except instead of using a 2X4, I just used my 48" carpenter's level as a straight edge to get the lights parallel to each other. Used the same level to adjust the vertical alignment. Hadn't seen the article, just used common sense. Glad to have written confirmation. Thanks Mike!
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-17-2015, 03:37 PM   #4
Fullraceflathead
Fullraceflathead's Avatar
Thanks for the info. That's a Great way to set them and should be very accurate using the Carpenters Level.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 03-17-2015, 05:14 PM   #5
SeaSlugs
SeaSlugs's Avatar
this works great granted the surface your parked on is level.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 03-17-2015, 06:34 PM   #6
Willie Krash
It is in the post to make sure the car is level.
Mike Stitt
-Henry Ford
Old 03-17-2015, 07:31 PM   #7
CarlG
CarlG's Avatar
If you do it in your garage, there's a pretty good chance it will be "near" level.
Alaskan A's
Old 03-18-2015, 05:47 PM   #8
John/CT
John/CT's Avatar
Could you please source the Walt Langill article?
John/CT is offline   Reply With Quote
Old 03-19-2015, 07:55 PM   #9
ODFever
ODFever's Avatar
I'm so glad I saw this thread. I have to adjust the headlights on my A. A friend of mine, who owns a '31 coupe, told me to shine the lights on the garage door and adjust them. I know that works for modern cars, but I like the idea of using my 4' carpenter's level instead. It is more precise than eyeballing the adjustment. This information means I can adjust the headlights without even taking the car out of the garage!! Thanks!
ODFever
1930 Ford Model A Town Sedan "Alyssa"
ODFever is offline   Reply With Quote
Old 03-20-2015, 08:35 AM   #10
whirnot
whirnot's Avatar
Actually not always, most houses being built today have a garage floor that is sloped 1/8" to 1/4" per foot, towards the floor for drainage.
But great information, I will use it on my cars.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
1931 Coupe
2 Smith Motor Compressors
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 03-20-2015, 09:19 AM   #11
C26Pinelake
Thanks Willie, I will try it when I an get thru the snow to. The barn. Wayne
C26Pinelake is offline   Reply With Quote
Old 03-20-2015, 01:52 PM   #12
CarlG
CarlG's Avatar
Originally Posted by whirnot View Post
Actually not always, most houses being built today have a garage floor that is sloped 1/8" to 1/4" per foot, towards the floor (door?) for drainage.
That's why I said "near" level. If that's a concern, you can always compensate for that by using a piece of 1X under the wheels closest to the door.
Alaskan A's
Old 03-20-2015, 08:47 PM   #13
Willie Krash
John,
One of our club members scanned some material and put it into PDF files. It was a collection of material one of our members compiled over the years and has since passed away. It is a single page. I could send you the PDF.
Mike
Mike Stitt
-Henry Ford
Old 03-20-2015, 08:58 PM   #14
Jerry in Shasta
Jerry in Shasta's Avatar
Unhappy Re: Headlight Adjustment made easy
Just one problem, where do you find a straight 2x4???
JB
Just my W A G at the problem.
Jerry in Shasta is offline   Reply With Quote
Old 03-20-2015, 11:15 PM   #15
CarlG
CarlG's Avatar
JB
That's why I use a 4' carpenter's level.
Alaskan A's
Old 03-20-2015, 11:58 PM   #16
Stew Masche
Stew Masche's Avatar
Great idea. but don't forget you still need to 'focus' the beam of light.
Thanks,
Stew
Always one bad decision away from a good time.
Stew Masche is offline   Reply With Quote
Old 03-22-2015, 09:29 AM   #17
Ted Duke
I wouldn't worry about the level spot being quite level as the roads you drive on won't be level either. LOL
Seriously, that sounds like a good way to get them right.
Ted
Ted Duke is offline   Reply With Quote
Old 01-14-2018, 01:30 PM   #18
Bikerider58
Bikerider58's Avatar
Older thread, but very happy to find in the search results...
No wonder my headlights where terrible...pointing in different directions with one in the weeds and one in the trees. So much for P.O. saying they were good.
Using the 4 foot and short levels made it easy to do in the garage, so no searching for a warehouse area and adjusting in the dark.
For longer drives, I still plan to add driving lights.
Bikerider58 is offline   Reply With Quote
Old 01-14-2018, 02:11 PM   #19
Big hammer
I was asked to help a coworker on his project, he is a finicky person! I had to go get some parts and when I got back he had his level out. I said I was wondering when you where going to level things out! He said it doesn’t look right but the level says different. I stepped back and told him when it was level. Nowadays I maybe half a bubble off ! :-)
get a bigger hammer tap done
Old 01-15-2018, 08:17 AM   #20
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Big Hammer,
Dog here, How in the WORLD kin Ol' Bill kjust headlites??? He's a BUBBLE & a HALF off, jist standing still
SA Buster T.
"THE ASSISTANT GURU OF STUFF"
