Old 03-11-2015, 04:56 PM   #1
1938 Coupe
1938 Coupe's Avatar
Default Blue or green...what color do you see?
Engine enamel paint from Mac's. Antique Ford engine green correct color for engines from 1927 to 1941 is printed on the can. What color do you see?
Is blue green or is it green blue? It looks great except is this really the correct color used by Henry! Warning a quart of paint can paint a lot of motors...maybe should bought the spray can instead. Oh well....I can always use for touch ups!
"DON'T CRUSH IT....RESTORE IT"
1938 Coupe is offline   Reply With Quote
Old 03-11-2015, 06:08 PM   #2
Jack E/NJ
Jack E/NJ's Avatar
Default Re: Blue or green...what color do you see?
What kinda light are you illuminating with? Looks good to me.
Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 03-11-2015, 06:13 PM   #3
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Cute little 60, looks blue to me. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 03-11-2015, 06:54 PM   #4
CT AV8
CT AV8's Avatar
I would call that green and by the photo it looks accurate. I would call the engine in Walt's avatar blue.
CT AV8 is offline   Reply With Quote
Old 03-11-2015, 07:13 PM   #5
DD931
DD931's Avatar
I think it's green, but not the right green. It does have a blue cast, which the right color does not.
DD931 is offline   Reply With Quote
Old 03-11-2015, 07:33 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
I see one side blue and the other side green
Old 03-11-2015, 07:39 PM   #7
1938 Coupe
1938 Coupe's Avatar
Good photoshop job
Old 03-11-2015, 07:51 PM   #8
Admiral
Admiral's Avatar
Looks exactly like the stuff I got from Mac's. I also ordered a quart, which is probably enough to paint about three acres' worth of area. Mine looks like a really dark green, maybe darker than original but I don't care.
Admiral is offline   Reply With Quote
Old 03-11-2015, 09:38 PM   #9
r_reed
r_reed's Avatar
yellow.
1949 F-1 Flatrod II (flat paint, flat motor)
Keeping one more flathead alive
It smoked, but gave it up 7/26/2013
East Glenville NY
r_reed is offline   Reply With Quote
Old 03-11-2015, 10:37 PM   #10
B-O-B
B-O-B's Avatar
Did you stir & lift as you stirred the paint? I sold paint for a while & most times it was just the painter not stirring the paint the right way. They would just stir in a circle but you need to lift the paddle as you stir. jus saying!! Your pic does have a greenish cast to it.
B-O-B is offline   Reply With Quote
Old 03-12-2015, 12:31 AM   #11
1938 Coupe
1938 Coupe's Avatar
Jack E/NJ
just good old fashion daylight provided by mr.sunshine himself!
Old 03-12-2015, 01:29 AM   #12
ford38v8
ford38v8's Avatar
What Bob said. And next time dip that little engine all the way into the can.
Alan
Old 03-12-2015, 08:41 AM   #13
Blu Dice
Blu Dice's Avatar
I see blue/grey
4 doors are better than no doors!
Blu Dice is offline   Reply With Quote
Old 03-12-2015, 08:51 AM   #14
JM 35 Sedan
JM 35 Sedan's Avatar
Looks like white and gold to me
John
Old 03-12-2015, 08:53 AM   #15
Fibber Mcgee
Fibber Mcgee's Avatar
I knew this post would end up there.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
Old 03-12-2015, 09:58 AM   #16
1938 Coupe
1938 Coupe's Avatar
I tried that once and the motor shrunk and fell off the motor mounts!
Old 03-12-2015, 09:59 AM   #17
Blu Dice
Blu Dice's Avatar
I hate it when that happens!!
