Old 03-06-2015, 08:42 PM   #1
mrcorvair
Default dual action fuel pump
Is there a dual action fuel pump that will work on a 59 flathead?
I know that Ford made some dual action pumps starting in 1949.
Will these pumps work on my flathead?
The reason I'm asking is I will want my wipers to work when I'm traveling up the mountains I live in!
mrcorvair is offline   Reply With Quote
Old 03-06-2015, 09:45 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: dual action fuel pump
I have a couple of Blackstone Dual Action pumps, but I believe they are for earlier engines. How does one tell for sure?
Old 03-06-2015, 10:23 PM   #3
cmbrucew
cmbrucew's Avatar
Lawson
Ken ct could most likely tell you.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 03-07-2015, 09:55 AM   #4
Charlie ny
LC,
The early pumps have the small mounting face whereas the 8ba pumps
single or double action pumps have larger (longer) mounting face. The double action pump
versatility comes at a price, in my opinion, that price is a very stiff action. Speaking
for myself I cannot actuate a freshly rebuilt pump by hand. Often times when
I get a car so equipped in the shop I find the push rod is bent. JMHO !
Charlie ny
Charlie ny is offline   Reply With Quote
Old 03-07-2015, 09:59 AM   #5
Charlie ny
LC cont'd,
The pumps I cannot actuate by hand are the double action ones. Also
the push rod cup on the 8 ba type is noticably larger in diameter than the cup on
the early pump.
Charlie ny
Old 03-07-2015, 01:21 PM   #6
flatheadfan
flatheadfan's Avatar
I don't think you can put a Ford dual fuel pump on a 59 engine without undergoing some exotic machine work to the block. Note the pictures.
The actual mounting between the later flatheads and its' pre-49 brethren is very different. The later engine requires a taller mount without an oil filler. The older engines have an integrated fuel pump mount and oil filler. I guess, this could be resolved by using a later intake which has a separate oil filler tube on the 59 engine or a '46-'48 Canadian intake.
Where things get sticky is with the fuel pump rod. The early flatheads have two lengths of fuel pump rods based upon composition of the intake (aluminum-7.5" and cast iron-8.5"). The '49-'53 is a full 10" in length." But, the difference doesn't end there. The '49-'53 rod has a diameter of 0.432" (more beefier) whereas, the early rod diameters are 0.372". Which means the internal block bushing diameter is larger for the '49-'53. If you were determined to use the later pump you would need to remove the smaller block bushing and bore out and re-bush the hole to accommodate the larger diameter rod. Hence, some complicated ($$), machine work.
If the wiper "pause effect" due to low vacuum is a problem you can't live with give some thought about going to either an electric wiper or use a vacuum reserve canister tank. I think you will find it would be much cheaper in the short run and the long run!
Hope this helps.
Tom
flatheadfan is offline   Reply With Quote
Old 03-07-2015, 03:57 PM   #7
tubman
tubman's Avatar
I bought a double action pump for my 8BA, but never installed it after seeing how much stiffer the action was and checking on these forums. I am thinking about adding a vacuum resevoir for the wiper. I have never used on for wipers, but I do have one om a '68 Corvette that will close the headlights with the engine off, so I think the capacity is there. Has anyone done this?
Old 03-07-2015, 04:18 PM   #8
Kube
Super Moderator
Kube's Avatar
Here's the cat's meow for good wiper operation on '42 - '48 Fords and Merc's. Any of you guys ever seen a complete kit in the box?
These tanks mounted beneath the front fender and were designed to do just what you guys are talking about... keep those wipers working at all times.
Old 03-08-2015, 05:12 PM   #9
John R
Generic vacuum tanks for retrofit were available aftermarket back in the day. I got one from J.C. Whitney about 35 years ago. Still have it. The tank is very similar to the one that Kube shows. Also has a inlet check valve.
Those who do not move do not die, but are they not already dead?
John R is offline   Reply With Quote
Old 03-08-2015, 07:04 PM   #10
mrcorvair
Anybody want to sell one of these vacuum kits?
Old 03-09-2015, 07:04 AM   #11
tubman
tubman's Avatar
Summit Racing lists vacuum reservoirs of many shapes and sizes. Most come with the proper fittings and check valve, and some also come with a mounting bracket. About $40.00.
Old 03-09-2015, 07:13 PM   #12
mrcorvair
Thanks everyone. It looks like I'll be placing an order with Summitt.
Old 03-09-2015, 07:22 PM   #13
DD931
DD931's Avatar
OK, Kube, you've whetted my appetite!! Haven't seen one in years. Do you know anyone selling a repro?
DD931 is offline   Reply With Quote
