Old 02-16-2015, 11:55 AM   #1
oldbike99
oldbike99's Avatar
Default Problem with replacement Tillotson carbs?
Does anyone know of a problem with replacement Tillotson carbs? I have called two suppliers and both have said they have discontinued stocking them. Thank you for any information you might have
oldbike99 is offline   Reply With Quote
Old 02-16-2015, 03:24 PM   #2
JD Miller
Default Re: Problem with replacement Tillotson carbs?
They are junk!
Both Bratton's and Snyder's don't carry them anymore.
I bought one from Bratton's last spring. It leaked like a sieve; all the time.
Called Bratton's and they reported there were so many problems with these repops and the manufacturer would not stand behind them. They refunded my money and that was when I was told they were no longer stocking this item
Shortly before that time Snyder's had decided not to stock the repop Tillotson.
They look nice but that's about as far as it goes. Save your money and get a good rebuilt Zenith.
JD Miller is offline   Reply With Quote
Old 02-16-2015, 06:47 PM   #3
raprice22
I may be wrong, but if I remember correctly, the Tillotson carbs were made of pot metal and didn't stand up well to long term usage.
The Zeniths are much better.
Rog
raprice22 is offline   Reply With Quote
Old 02-17-2015, 09:16 AM   #4
oldbike99
oldbike99's Avatar
I am not concerned with old Tillotson carbs, but am wondering about the reproductions. Where do they leak? Needle and seat? Gaskets? There are some very reputable venders still selling them, so some of them must be good.
Old 02-17-2015, 10:58 AM   #5
JD Miller
When Bratton's and Snyder's both dropped selling these repops that was good enough for me.
A better question would be; where don't they leak? When I pay over $300.00 for a new carb I should not have to tear it apart to make it function properly.
But then, It's your money so if you want to purchase a "pig in a poke" then go for it. You then have the opportunity to gain some great knowledge as you work your way through the carb fixing all of its problems.
Have fun!
