#1 |
Is it important to have garage at 70 degrees to paint?
I know I can, I know I can http://www.flickr.com/photos/waltsprojects/ |
#2 |
What does the manufacturer's specs call for? 70d vs. ?
Henry Ford designed the flathead without the aid of a computer. |
#3 |
The item your painting has to be warm enough.
Tim Carlig |
#4 |
Yes, it is very important to have the air & metal at the proper temp for the best adhesion & flow. You can choose a hardener as low as 60 degrees with most paints.
"Jealousy is a Sad Pathetic Character Trait Generally Held By The Lazy, Immoral Dregs of Society" 1955 Chevy Altered W.B. Gasser 1955 Nash Amb. Cust. Lemans 1957 T-Bird 1964 Pontiac Grand Prix 2 DR HT 1966 Pontiac Catalina Conv 1966 AMC Ambassador DPL 2 DR HT 1966 AMC Ambassador Cust 2DR HT 1967 AMC Marlin 1967 Toronado 1973 Chevy Nova Full Chassis Car 1992 Jag XJS Conv 1992 Jag XJS 2 DR Coupe 2007 Cadillac XLR-V Supercharged Roadster 2008 Southern Customs Avalanche |
#5 |
I have painted in 35-45 temps---but then the painted items have to be mover to a warm place ---I tried some samples, even after 1 week in cold temps the sample seemed dry when cold, but got soft and sticky when warmed --but another week in warm hardened it ----but long term exposure testing can take years--I have some samples of other experiments going on 20+ years of testing
#6 |
#7 |
I have a heated garage. And use heat lamps to warm the small parts that I paint.
Works really great. No paint runs and paint dries to a hard finish. |
#8 |
It is after the painting that the heat needs to be kept up ---till the paint cures, 24-48 hours
#9 |
Painted the cab today at 60 degrees. All went well, will check in am and see how it looks.
