Old 01-29-2015, 10:28 PM   #1
clocey
clocey's Avatar
Default U-joint grease
I am installing a new u-joint during an engine rebuild and I need to know how much grease to use. Do I fully pack the u-joint and housing before closing things up?
Thanks in advance for your help
Curt
1930 Model A Fordor Murray Body
clocey is offline   Reply With Quote
Old 01-29-2015, 11:58 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: U-joint grease
Curt
Yes. Another easy way to know when it is full is to remove the speedo drive gear from the torque tube and start filling the U-joint cavity with grease. When you start to see the grease coming out the speedo housing hole, you know you are full.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-30-2015, 12:45 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Yep, it takes about a full grease tube to fill the cavity, and don't forget the gasket on each side of the thrust cup.
Also be sure to grease the outside of the thrust cup, since it's the pivot point for the torque tube. I've seen them scored from being left dry.
Old 01-30-2015, 03:37 AM   #4
C26Pinelake
That is exactly what mine took, a full tube. Now I gphave to ask the mechanic about the gaskets ???
Wayne
C26Pinelake is offline   Reply With Quote
Old 01-30-2015, 06:33 AM   #5
clocey
clocey's Avatar
Thanks guys. Any recommendations on the grease to use?
Old 01-30-2015, 07:19 AM   #6
Mitch//pa
use a good quality modern high temp wheel bearing grease.
Old 01-30-2015, 09:13 AM   #7
Ron Lachniet
Ron Lachniet's Avatar
I know it's been said many times before but John Deere corn head grease was formulated for this type of application and it works real well. Mix some in gear oil and it also makes a good steering box lube.
Ron Lachniet is offline   Reply With Quote
