01-23-2015, 08:51 AM | #1 |
8BA with early toploader "18" Case (32 -34)
I searched & didn't find the info. I needed, this is a continuation of my earlier inquiry about bellhousing gaskets, which indicate they were made to possibly shim the transmission & clutch assembly...
I have an 8BA with a 10" clutch mated to an "early" 1934 toploader "18 case", I know that the practise was to "relieve" the bell housing to fit the larger clutch (the later toploaders were designed to come back straight & then round in for clearance) - My combination did work as this car was built in the early 60's & driven until 1970, I then got it running & drove it onto my hoist as well so I'm not asking if it will work or not, rather does anyone have suggestions on how to do it better using the same parts ? This picture shows how the transmission "horn" was ground down. And then the weights on the pressure plate were flattened... And here is the new pressure plate for comparison... My plan was to fit everything together & see if the weights need to be ground down... maybe that was a first attempt & then the transmission bell was ground out later - I would like to avoid grinding the weights down, but if that's what has to be done for this combo, so be it - I was hoping that the experts here might be able to shed some light on this. Thanks in advance |
01-23-2015, 09:23 AM | #2 |
Re: 8BA with early toploader "18" Case (32 -34)
denns,
Do not grind the weights....get a 78 series case to make everything happy. This is a BIG stretch but if that 10" pressure plate worked at one time MAYBE disc wear is causing the weights to assume a different position. You'll end up hating yourself if you add shims....blah blah blah........there is no shortage of good 78 series cases available on the Barn. In many instances a 48 series case can be prob- limatic with a 10" clutch. Charlie ny |
01-23-2015, 09:59 AM | #3 |
X2 what Charlie said, however, I have always had good success using the '35 - '36 #48-xxxx cases with later '39 - ''48 gears and 10", and even up to 11" C&PP.
01-23-2015, 10:05 AM | #4 |
Setting it up statically will not allow for the weights wanting to move outboard (even if just a little bit) when the revs come up. If you want to use the old case, why not reuse the modified clutch cover? is there any reason to believe it is no good? Very often new is not better.
Mart. |
01-23-2015, 03:57 PM | #5 | |
01-23-2015, 04:01 PM | #6 |
01-23-2015, 04:16 PM | #7 |
Maybe another option is to go to a 9" clutch? A lot of us do this to help the engines rev faster anyway . . . and with a stock style engine, you'll not have an issue with the smaller surface area? Also, with the clutch fork weights being severely ground down with the current 10" clutch, I doubt it will have as much clamping force as a 9" that hasn't been mucked with.
No matter what path you take, have the pressure plate and flywheel balanced before you put it back together. Seems to me, all you'd need to do is have the flywheel re-drilled. Anybody else tried this? Dale |
01-23-2015, 04:18 PM | #8 |
Rather than make any changes, I suggest you obtain a Diaphram Pressure plate, as your flywheel is already drilled for a 10" clutch. Maybe no grinding needed at all
01-24-2015, 01:26 AM | #9 | |
All in all, I think a different pressure/clutch plate is the easiest 'solution' to the configuration. B&S |
01-24-2015, 04:32 AM | #10 |
No, B&S
I have one in my 32 and it has the same pattern as a long type. Bought it at my local NAPA store |
01-24-2015, 08:08 AM | #11 |
Get a 48 or 78 series transmission case.
01-24-2015, 09:53 AM | #12 | |
Okay, so my long range plan is to source a 48 or 78 series case with 9" clutch combo, unfortunately I just finished rebuilding my case, so I was looking for an easy solution (I know wishful thinking) :-) Thanks for the feedback, this whole flathead / toploader thing is new to me ! This sounds like a decent soltution for my current situation, I assume you use the release bearing & clutch disc that is used on a regular "fly weight" pressure plate ? & then just use the different pressure plate - Do you know what year/model your pressure plate is originally for ? Make sourcing one easier for me - thanks in advance ! |
01-25-2015, 08:04 AM | #13 |
Normally diaphram and Borg & Beck pressure plates have a GM or Chrysler bolt pattern. What he'll need to buy is known as a diaphram substitute pressure plate - these are designed to replace early Ford Long style clutches and will have the Long bolt pattern.
01-25-2015, 08:39 AM | #14 |
I was searching all over the internet, anyone have a part # for this type of pressure plate ?
Thanks in advance Jeremy |
01-26-2015, 11:57 AM | #15 |
For anyone interested and for Jeremy, the part is a Vapex part# CA0030. I think it is what we all used to call an "Auburn" clutch.
01-26-2015, 12:39 PM | #16 |
That appears to be an 83-85 Ford Truck and Bronco pressure plate, correct?
01-26-2015, 12:47 PM | #17 |
Hey, I didn't put 2 and 2 together, I didn't realise this was the trans from Snoopy over on the hamb. Been following the resurrection. I'd still just bolt in the "previously enjoyed" pressure plate (yeah, "clutch cover" is an old fashioned expression).
Good luck with it. Mart. |
01-26-2015, 01:20 PM | #18 | ||
http://www.rockauto.com/catalog/more...610&cc=1105760 I ordered a "dealer closeout" one for $30 (last one) on Rock Auto yesterday just to compare & have as an option. The "360030" is a common number, you can find uprated/racing etc. clutches using the same number... Quote:
01-26-2015, 01:33 PM | #19 |
"Yes & a pile of other Ford models, just have to watch out because they also used 11" clutch on some as well, here is a link for what the 10" looks like :
http://www.rockauto.com/catalog/more...610&cc=1105760" Thanks for the update, think I will go with a 9 inch, should accelerate quicker, but still good information to have. |
01-26-2015, 01:34 PM | #20 |
Make sure the fingers of the diaphragm don't close together and contact the inner part of the bearing carrier. You ought to be able to watch through the inspection hole and make sure all is well.
From the illustration the fingers appear to be curved, so hopefully they ought to be compatible with the flat face of the release bearing. Mart. |
