#1 |
I have just about got the back of the cab on my 36 pickup straightened up and are about to replace the rockers. There wasn't much left of them. I had some help taking what was left off, while I was working on the front fenders. My helper was certified in body work, but was not up to the task of replacing rocker panels. Both were removed before he was fired! I did not see where the originals were welded. I need to know how much of the perimeter was welded,and where it was spot welded. I am trying to install as close to original as possible. Thanks for any help, Ron
Last edited by rottenron36; 01-22-2015 at 04:04 PM. Reason: more information, spelling |
#2 |
I can grab a pic when I get home of a spare cab I have
#3 |
That would be GREAT, and appreciated. Thanks Ron
#4 |
Sure appears to be spot welded, I see no welds at all.
#5 |
They are spot welded on the inner lip. Block sand the lip to see the weld dimples.
I got a pair from Northern Classic Trucks and they were a perfect fit! Not hard to do. Good luck on your project! |
#6 |
#7 |
As always GREAT help, Thanks for your support. Ron
#8 |
I replaced the ones on my '36 p/u with the epoxy that body shops use now. Used cleco's to hold in place and replace them with counter-sunk pop rivets. I did it this way so that I could clean everything inside the rockers up and paint in order to rust proof the area internally. Seems to me that spot welding them burns away any protection there. They have been on for 6 years now and everything is fine. That epoxy is great stuff. If you go this way, make sure you work it in the correct temperature range or even get the "hot" range and do the job when it is cool so that it buys you more time to properly place the panels. Once it starts to set, you won't be able to get it apart. You can buy the stuff on line and you might find a body shop to loan you the double caulking gun because it is expensive and you may not do the job again any time soon. FWIW.
