Old 01-06-2015, 02:16 PM   #1
31 Model A
31 Model A's Avatar
Location: Here I am in front of Todd's Grocery in 1931 selling Grit newspapers
Default Installing LED stoplights?
Does a part of the center divider have to be cut out to accommodate the wire to keep it from being cut into when putting the light back into the taillight section?
"Bullshit and Brilliance Comes with Age and Experience"
"Hey Lady, ya wanna buy a Grit?"
"If you don't learn to laugh at trouble, you won't have anything to laugh at when you're old" Will Rogers
31 Model A is offline   Reply With Quote
Old 01-06-2015, 02:58 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Installing LED stoplights?
I installed some for a friend and didn't have to do any cutting.
Old 01-06-2015, 03:11 PM   #3
Ford1931
Ford1931's Avatar
Are there LED lights that look fairly stock when they are not on? I have seen some that really look out of place on a stock car.
Ford1931 is offline   Reply With Quote
Old 01-06-2015, 03:34 PM   #4
31 Model A
31 Model A's Avatar
These came from Snyders. The red wire that connect top board with bottom board cuts in the middle of the seperation.
Old 01-06-2015, 03:45 PM   #5
Patrick L.
Patrick L.'s Avatar
Not sure what you meant by the last sentence, but, I cut the jumper wire [red]. There were no instructions stating that, but, apparently these lights are for other installations also.
Old 01-06-2015, 03:48 PM   #6
Patrick L.
Patrick L.'s Avatar
The only ones that I've seen look stock until they are lit.
Old 01-06-2015, 03:50 PM   #7
Tom Wesenberg
Yes, the ones I installed for a friend also needed to have the red wire cut.
Old 01-06-2015, 03:53 PM   #8
CarlG
CarlG's Avatar
I just installed these in my regular Model A teacup tail lights. They look pretty much like the original glass lenses. If you prefer, they come in red/amber also. Most of our guys (me included) opted for the all red, just to be consistent with what people expect.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 01-06-2015, 04:03 PM   #9
Y-Blockhead
Y-Blockhead's Avatar
I seem to remember if you install with the red wire not cut, all the LED's are on when the lights are turned on and become brighter when the brakes are applied.
When the red wire is cut, the upper and lower LED's are separated like the stock light, bottom side on with headlights, top side on with brakes.
If using option 1, uncut wire, you need to modify the separator for the wire to pass thru.
Old 01-06-2015, 04:15 PM   #10
tbirdtbird
you don't even need the separator with the LEDs pictured. Notching it would cause no harm
'31 180A
tbirdtbird is offline   Reply With Quote
Old 01-06-2015, 04:18 PM   #11
31 Model A
31 Model A's Avatar
Got them in, did not cut any wire, brake light left works great, break light right does not work. Thought maybe I had cut the jumper red wire, took it back off, no cut, put the old bulbs back in, brake light still doesn't work. Put LED back on, running light left side works, gets brighter when brake is applied. Right side...nothing, no running nor stop.
Old 01-06-2015, 04:21 PM   #12
31 Model A
31 Model A's Avatar
The running light right side was working about ten days ago when I last ran Sarah, break light, can't say.
Old 01-06-2015, 04:22 PM   #13
Y-Blockhead
Check your grounds...
Old 01-06-2015, 04:35 PM   #14
31 Model A
31 Model A's Avatar
Will do first thing tomorrow when the garage has heat again.
Old 01-06-2015, 04:38 PM   #15
Patrick L.
Patrick L.'s Avatar
Sounds like its time to get out the volt meter or test light. Once you the right side is working, I think you'll probably want to cut the red jumper.
If you decide to hook up signals, that'll be fun. But, we'll get them working too.
Old 01-06-2015, 04:58 PM   #16
31 Model A
31 Model A's Avatar
Volt Meter????? What's a Volt Meter????? Just a bit of jocularity!!!! I'll put one on my shopping list for my next trip out. Sarah best not start talking diamond studded headlights!!!!!!
Turn signals???? Started on them today too.
Time for a cup of joe..................
Old 01-06-2015, 05:40 PM   #17
31 Model A
31 Model A's Avatar
I decided to go with Logo-Lites. I see many A owners have them and they look OK. I got the lights bolted to the bumpers today, no wiring yet. Maybe tomorrow.
I'll do some reading tonight in my A books about tail lights.
-10 to -20 here tomorrow wind chill..................Brrrrr!!!
Old 01-06-2015, 05:44 PM   #18
31 Model A
31 Model A's Avatar
I went with all red, to be noticed better. I doubt if I'll ever do any night time driving but quite a bit of daylight. Now, if the whole light is brighter when brake is applied, would that not be more noticeable?
Old 01-06-2015, 06:25 PM   #19
Y-Blockhead
I would certainly think so. That is the way mine is set up. I also have my center light, looks clear but has 12 5mm RED LED's in it.
Old 01-06-2015, 06:35 PM   #20
31 Model A
31 Model A's Avatar
What could I have done, unknowing, that could have disrupted the electric flow to the right tail light? As I said, it was working just fine about ten days ago. The only thing I did electrical today was replace the terminal box top. It was cracked. Nothing else electrical.
