01-02-2015, 06:24 PM | #1 |
Different Horn
This horn is different than others I have, was wondering if anyone knew anything about it...would it be authentic on my 1929 Cabriolet?image.jpg
The only thing worth learning is what you learn after you know it all !! |
01-02-2015, 06:27 PM | #2 | |
Re: Different Horn
01-02-2015, 06:32 PM | #3 |
Re: Different Horn
Lopez, I sent you a PM.
01-02-2015, 07:34 PM | #4 |
Re: Different Horn
That is for a 1928 model A & can be very expensive..
01-02-2015, 08:04 PM | #5 |
Re: Different Horn
From the RG&JS the horn would be correct for a 1929 vehicle.
RG&JS page 19-3 Revised 2011 E. A. Laboratories horn used from Mid 1928 through 1929. E. A. Laboratories horn used from 1927 - Early 1928
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
01-02-2015, 08:12 PM | #6 |
Re: Different Horn
http://MODELABASICS.com/ How Things Work on a Model "A" Ford Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles. |
01-02-2015, 08:18 PM | #7 |
Re: Different Horn
Yes it appears to be a mix of the two sketches in the RG&JS. It has the "Adjust" and the raised end rather than the indented end???
01-02-2015, 08:25 PM | #8 |
Re: Different Horn
The one in the photo is correct....
01-02-2015, 08:33 PM | #9 |
Re: Different Horn
Are you saying that there is an error in sketches in the RG&JS page 19-3 Revised 2011?
In re reading the RG&JS the horn appears to be the 1927 to early 1928 EA horn, but with the "ADJUST' engraving that was used in the mid 1928 to 1929 EA Horn.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? Last edited by 160B; 01-02-2015 at 08:52 PM. |
01-02-2015, 09:10 PM | #10 |
Re: Different Horn
1928
01-03-2015, 12:46 AM | #11 | |
Re: Different Horn
The 1928 version had the raised centre with the embossed writing, adjust. screw & cover screw. That is the one in the photo; 1928. Later for 1929 on, the cover is as shown in those JS drawings . At the most, they [ the '28 version cover] could have been used into early '29, depending on where the car was assembled. |
01-03-2015, 11:07 AM | #12 |
Re: Different Horn
Thanks guys for inpute, it must be the early 28 model as the center is raised like in JS drawings...will finish restoring it.
01-03-2015, 02:14 PM | #13 | |
Re: Different Horn
JSC have done a wonder job. Ya, i missed it when I have looked in the JS. The only reason I said it was "correct" is, it looks right from the E.A. horn that I have. |
01-03-2015, 02:17 PM | #14 |
Re: Different Horn
Sometimes the illustrations are an artist rendering and not an actual photo. I am not sure about the horn illustrations.
