Old 12-24-2014, 12:38 PM   #1
ThomasN
ThomasN's Avatar
Question Install seat in 53 Victoria
I am ready to install the front seat in my 53 Vic and see a wire from one side to the other for linkage I think. Is there supposed to be some kind of return spring attached? There is a peg sticking out in the center with what looks like it should have something attached like a spring or something.
Thanks in advance,
ThomasN is offline   Reply With Quote
Old 12-24-2014, 12:50 PM   #2
charles in east texas
charles in east texas's Avatar
Default Re: Install seat in 53 Victoria
That wire going across releases the latch on the passenger side. Before I installed the seat, I would set in it and try the release lever and make sure everything is working properly, moving back and forth, etc. Charles
charles in east texas is offline   Reply With Quote
Old 12-24-2014, 01:15 PM   #3
ThomasN
ThomasN's Avatar
I agree, but my concern is there looks like there may be a spring attached to it in the center. There is a stud sticking out from the frame with an eyelet and the wire has a matching eyelet. The wire has a somewhat of a bow towards the stud eyelet. It just appears as I am missing a spring or something. This car was a basket case when I got it 3 years ago. I bought the books, but nothing on the seat construction so far.
Thanks
Old 12-24-2014, 09:00 PM   #4
Merc Cruzer
Merc Cruzer's Avatar
53' Mercury seat, hope it helps. If you want I can send you the picture and you can then zoom in on it.
[email protected]
Merc Cruzer is offline   Reply With Quote
Old 12-24-2014, 10:01 PM   #5
ThomasN
ThomasN's Avatar
[email protected]
Actually it does help, I can see that the wire is hooked to the stationary eyelet. This is exactly what I needed,
Thank you
