Old 12-22-2014, 08:04 PM   #1
Mike B
Default The "heater" thread got me wondering...how to run a hot water heater in a FH?
Do you need water pumps with an outlet fitting on them?
Mike B is offline   Reply With Quote
Old 12-22-2014, 08:14 PM   #2
Zeke...PA
Zeke...PA's Avatar
Default Re: The "heater" thread got me wondering...how to run a hot water heater in a FH?
No they have a return fitting that can be inserted in the bottom radiator hose and the supply comes from a fitting in the head, which is normally a shut off valve. Some later water pumps have a return pipe fitting normally a plug in the housing. Zeke
Only problem with retirement is never a day off
Zeke...PA is offline   Reply With Quote
Old 12-22-2014, 08:15 PM   #3
ford38v8
ford38v8's Avatar
Mike, the below pictured hose fitting is available from C&G (and others). It is installed on the lower radiator hose. The upper heater hose connects to a valve on the head.
Alan
Old 12-22-2014, 08:23 PM   #4
Mike B
So...I can come out of (or into) one head, then to the lower radiator hose, OR the WP?
Thanks
Old 12-22-2014, 08:31 PM   #5
flatheadfan
flatheadfan's Avatar
I have four early flatheads and they all have hot water heaters. Basically, they are trouble free, require little if any maintenance, relatively easy to install and do put out enough heat to keep a coupe or roadster comfortable. Note the hook-up below.
Tom
flatheadfan is offline   Reply With Quote
Old 12-22-2014, 08:36 PM   #6
Mike B
Thanks Fan...clear now, I have two WP's that are "tight" that have fittings on them now...one I believe is plugged, and have an outlet on the head with a valve on it...so should be easy to take care of!
Pics be worth a billion words!
Thanks again!
Old 12-22-2014, 09:42 PM   #7
Drbrown
Drbrown's Avatar
As a possible addition to the heater system, my '47 has a flow control valve in the heater hose running between the heater and the lower hose. A choke cable at the dash board opens and closes the flow control valve to increase or decrease the hot water flow through the heater core and thus the temperature of the heater output.
Drbrown is offline   Reply With Quote
Old 12-22-2014, 10:15 PM   #8
Mike B
That would/should, eliminate a shut off valve in the head for summer time as well, nice.
Old 12-23-2014, 06:24 AM   #9
wingerdinger
wingerdinger's Avatar
I have a rather odd plumbing arrangement on my `35 big truck. Both water pumps have a fitting with a hose coming from them, and they are 'teed' together before going into the heater housing. The tee is plastic, so I can assume that it is not Ford correct.
The outlet (or inlet) hose comes from the drivers side front of the block, with a fitting and shut off valve on that fitting. I think I remember seeing a valve on the drivers side water pump fitting as well. This is from memory, I only noticed because I had to drop the oil pan to change the clutch. I'll have to go out and take a few pictures.
I just got the truck, non-running. a few months ago, so I have never tried the heater.
Could all that be to increase the flow for more heat? or?
wingerdinger is offline   Reply With Quote
Old 12-23-2014, 10:14 AM   #10
nbrskn
I Put a shutoff in the head side because the water would get hot back into the heater. By convection I supose
nbrskn is offline   Reply With Quote
Old 12-23-2014, 10:28 AM   #11
PeterC
PeterC's Avatar
May be controversial - but my heater performs well with passenger pump serving as output for hot water supply and return going back in passenger head at the threaded bung where a temp sensor might go
PeterC is offline   Reply With Quote
Old 12-23-2014, 12:05 PM   #12
sidevalve8ba
sidevalve8ba's Avatar
This set-up on my 8ba works just fine for me. Top hose at cylinder head with cut-off valve. Lower hose at water pump.
Cars are like potato chips, its hard to have just one.
sidevalve8ba is offline   Reply With Quote
Old 12-23-2014, 12:12 PM   #13
Mike B
I "think" that is how the Pilot was plumbed that I used the engine from...will look at the pumps I took off the Pilot engine, as I recall, there was something coming off the pass side pump, to a copper tube that went up and over the engine towards the firewall.
Also, on the pass head is a shut off valve as well.
Old 12-23-2014, 02:29 PM   #14
Drbrown
Drbrown's Avatar
Whoever installed that choke cable operated flow-control valve in my '47 apparently also removed the manual shut-off valve on the cylinder head. I wonder how water-tight the flow-control valve is .... it might not make a water-tight closure.
sidevalve8ba: Nice looking power plant !
