12-18-2014, 01:22 AM | #1 |
Metal tube that carries the wiring loom to the Cut Out.
If I understand correctly, on the '28's and '29's they had a Metal Tube that carried the wire loom to the Generator Cut Out.
I have a '28 but I'm missing this Metal Tube. Is there any chance someone has the dimensions of it so I can fabricate one for my Truck? It looks fairly simple but; How long?, Outside Diameter of Tubing?, What size Radius and it's location? It seems like 1/2" Conduit might be close. Of course an restorable original or if someone could trace theirs onto paper would be Great! Thanks. |
12-18-2014, 02:11 AM | #2 |
Re: Metal tube that carries the wiring loom to the Cut Out.
I would just buy the tube with wire from one of the Model A parts dealers. 1/2" conduit is too large.
I don't have any specs, but am looking for a good original tube myself. |
12-18-2014, 02:39 AM | #3 |
Refer to the MAFCA "Model A Restoration Guidelines", they will tell you all you need to know about your question.
12-18-2014, 03:52 AM | #4 |
Check reply #3 for a picture of my original conduit. The previous owner didn't have the tubing clamped tight to the water inlet, so it wore a hole in the bottom side from vibration. That's why I'd like to find a good original tube.
http://www.fordbarn.com/forum/showth...erator+conduit |
12-18-2014, 04:38 AM | #5 |
I bought the aftermarket one which was pretty good, not a show car mind you
https://automotiveamerican.files.wor...2357.jpg?w=460
Kevin Flood West Berkshire UK Member MAFCGB, VHRA, SAH, Brooklands Trust Sporadic progress on My 1929 Sport Coupe can be found here along with my blog http://automotiveamerican.com/ |
12-18-2014, 04:38 AM | #6 |
12-18-2014, 11:34 AM | #7 |
There is one listed as NOS on E-Bay right now with the Opening bid wanted of $50.00.. No Bids as of yet..
12-18-2014, 01:53 PM | #8 |
Unless its a points show car, I would avoid the metal tube. The metal tube is a fire hazard and that is probably why it was discontinued . If the metal conduit shorts out against the terminal in the terminal box it will cause most of the wiring to burn. It happened once for me and I have known others that had the same experience
12-18-2014, 01:58 PM | #9 | |
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
12-18-2014, 02:04 PM | #10 |
I've never seen one repro-ed. I don't mind a repro.
12-18-2014, 02:10 PM | #11 |
Thanks for the link. I see enough photos of it to make one. Looks like 3/8 diameter tubing should work. I like how Ford had it flared into the Terminal Box.
12-18-2014, 06:50 PM | #12 |
Here's mine from my '29 sport coupe. It's original.
Outside diameter is 1/2" thin wall tubing. Total length aprox. 24". Flared at both ends. Oval exit hole in first picture has an extra piece of metal added so it doesn't cut the wire.
1929 Coupe 1930 Coupe 1935 Ford 5 window coupe |
12-18-2014, 08:54 PM | #13 |
I have two. The original on my '28 Phaeton has a seam. The reproduction on my self, does not.
The original tubing had a seam; the reproductions did not. |
12-18-2014, 10:23 PM | #14 |
12-18-2014, 10:32 PM | #15 |
Would J B Weld work?
12-18-2014, 11:10 PM | #16 |
12-18-2014, 11:22 PM | #17 |
Should be able to get by with some 1/2" fuel/hydraulic hardline. Peformance shops and or semi truck repair places may have something you could use.
personally when dealing with wire in conduit in a high heat/vibration area i would ditch the metal tube. It will eventually wear the insulation out. The THHN i think it is wire might stand up to this better but wouldnt look correct. You may be able to get wires inside a rubber hose then slip the hose inside the metal tube, would prevent vibration and would be hidden if its a few inches shorter than the tube itself....
1929 Model AA - Need long splash aprons! |
12-19-2014, 12:28 AM | #18 |
I agree, using some rubber hose/vacuum line around the actual wires on the inside would be safe and hidden if done right.
12-19-2014, 12:32 AM | #19 |
Thank You! Those photos are Nice.That looks perfect.
12-19-2014, 12:35 AM | #20 | |
