Old 11-23-2014, 05:37 AM   #1
Ianrhall
Default Lowering a 40,s truck
I have a 44 ford v8 truck coming. I want to lower it approx 3-4" all round.
Seems to be many opinions on this
A friend used a 3" drop and dropped leaves and then flipped the rear axle
This has made the truck maybe too low and the running board is level with the ground, I would prefer a slight rake. Flipping the axle was a lot of work and now we are looking at how to raise it a little!
So could I
Fit drop axle and use stock front springs
Reverse long rear leaf and remove some other leaves
Leave front axle but as above reverse the eyes and remove some leaves
Same at rear
The latter plan would be virtually no cost, although all of the bushes are likely to be shot
It's just a question of whether to order an axle or not, I'm in the uk so will need to get it shipped with the truck
Thanks
Ian
Ianrhall is offline   Reply With Quote
Old 11-23-2014, 06:07 AM   #2
scooder
Default Re: Lowering a 40,s truck
Ian, on the front of these there ain't a bunch of room for suspension travel stock,(least on my '42 there's not lots of room) so reversed spring eyes and removed leaves is gonna have you bottoming out a fair bit I think. So going with a dropped axle is probably better. As for the back, I spec removing leaves would suit you, as I spec your not gonna use it as a pickup, what with all this lowering business, shame. I like pickups to be pickups, and used and kept as such.
You keeping the flathead in it?
Your probably gonna be sent to the HAMB.
Martin.
Also in England.
scooder is offline   Reply With Quote
Old 11-23-2014, 06:16 AM   #3
Ianrhall
Any pics of your 42?
Yes definitely keeping the flattie. It sits way too high so have to do something, intend on using it so don't want a radical drop, airbags would be cool tho!!
Old 11-23-2014, 10:01 AM   #4
cmbrucew
cmbrucew's Avatar
You might want to keep it stock as Ford did not make many 1944 non military trucks.
There was a war going on that year.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 11-23-2014, 10:07 AM   #5
Ianrhall
Only going to drop it a bit and put dual system on, that's about it. I won't cut it up!
Pretty rare then is it?
Ian
Old 11-23-2014, 10:08 AM   #6
Ianrhall
Could it be a military truck!
Old 11-23-2014, 12:45 PM   #7
waterboychuck
waterboychuck's Avatar
I installed a 3 inch dropped axle on the front and removed 1/2 of the leafs in the rear. I don't think that I'll be hauling anything and the ride is better. Send me a PM with your email and I send you some photos. Mine are too large for this sight.
The sign of a good craftsman is how well they cover up their mistakes.
waterboychuck is offline   Reply With Quote
Old 11-23-2014, 03:03 PM   #8
Ken Crans
Ken Crans's Avatar
On my 47 i had i used a F-1 axle to convert to tube shocks eliminating the lever actions and having the F1 brakes which stop a whole lot better.. Used reverse main leaves with every other leave missing i believe it was 5 -7 leaves Had to alter front shackle for travel Did the same in the rear with reversed eyed and a 63 F100 9 in. sat perfect and rode real nice Check in Avitar for pics There a lot if different options and your preference good luck
Ken Crans is offline   Reply With Quote
Old 11-29-2014, 02:40 PM   #9
Sixseven
Sixseven's Avatar
A PO of my truck removed several rear leaf springs and it didn't seem to lower the rear but for the thickness of the spring. It lessens the ride stiffness which is why I suspect it was done.
Sixseven is offline   Reply With Quote
Old 11-29-2014, 03:01 PM   #10
Ianrhall
Yes, a friend if mine has just lowered his 47 by flipping the axle but leaving the leaf packs. It has dropped it 4.5" but ride is very hard. It still has 10 leaves in the packs, good an to remove 4 or 5 I think.
I intend to remove some leaves and possibly either flip the rear shackles or turn the long leaf over(have to re bend it of course)
I hope this will achieve around 3-4" of drop
Whether I will still have to notch the chassis remains to be seen!
Ian
Old 11-29-2014, 03:58 PM   #11
TonyM
TonyM's Avatar
Bruce
Yep, not many 1944 Civilian Ford Trucks. Leave it stock.
TonyM is offline   Reply With Quote
Old 11-29-2014, 04:14 PM   #12
Ianrhall
I'm only lowering it a bit, could revert it back!!
Old 11-29-2014, 05:51 PM   #13
funrunr
funrunr's Avatar
I went with drop axle and left original spring in front, my biggest mistake was going mono leaf in rear. Looks great but very bouncy ride. I dont suggest it to no one. (40 coupe, not truck but same principle)
Thank God
this is only a hobby!
funrunr is offline   Reply With Quote
Old 11-30-2014, 08:20 AM   #14
scooder
Not really the same principal, his truck has parallel leaf springs front and back. Totally different setup, sorry.
Ian, you say 1944, I'm interested in how you've got this info. I ask purely because for instance most "1942" pickups aren't, majority are 46-47's.
Be quite cool if it is a 1944, cus as been stated, very few civilian trucks were made in the war years, only allowed if you could prove you really needed a new truck, and had to be in a needed industry, farming or such. Then you still had to jump through hoops to get on the waiting list.
Martin
Old 11-30-2014, 09:45 AM   #15
Ianrhall
I am told it is 44, we will see for sure when I have title in my hand. Will it be much the same truck 42-47?
Ian
Old 11-30-2014, 10:20 AM   #16
cmbrucew
cmbrucew's Avatar
Ian
That would depend on wither it was made for the military and also the country of origin.
Where is your truck coming from?
Bruce
Works good
Lasts long time
Old 11-30-2014, 10:21 AM   #17
Ianrhall
From Spokane WA
Ian
Old 11-30-2014, 11:52 AM   #18
AnthonyG
AnthonyG's Avatar
Has anybody used the Carbon fiber leafs? I've heard the ride is great and they are strong enough for light loads if you want to use it as a pickup? Better than stock ride. Much easier to work with due to so much lighter. Looks easy enough to mount under axles to lower. A bit expensive.
http://www.speedwaymotors.com/1935-4...-Kit,2210.html
Nomad
AnthonyG is offline   Reply With Quote
Old 11-30-2014, 12:13 PM   #19
Ianrhall
$750, I won't be using them!!
Old 11-30-2014, 01:20 PM   #20
Mike B
Ian, check with "Chris" here on Ford Barn, he had a 46? he lowered a tad and made it look nice...I'll see if I can find the thread for you.
Mike B is offline   Reply With Quote
