Old 11-13-2014, 10:33 AM   #1
Gary loves Fords
Gary loves Fords's Avatar
Default Putting Model A on battery tender
I have a question on charging my 1931 Model A Deluxe Phaeton. Can I put the positive clamp on the starter bolt and the negative on the frame, to keep the battery charged, without having to pull up the floor board to charge it? I am not real good with electrical chores. It seems my A is wired up in such a way, that the motor has to be be running for the lights and horn to work. It's the first A I have had that needs to be running for them to work. Any help will be greatly appreciated.
Gary loves Fords is offline   Reply With Quote
Old 11-13-2014, 10:38 AM   #2
roadster
roadster's Avatar
Default Re: Putting Model A on battery tender
Gary
you can do that "BUT"
put positive on frame and neg. on starter
roadster is offline   Reply With Quote
Old 11-13-2014, 10:39 AM   #3
Patrick L.
Patrick L.'s Avatar
You can connect a charger to the starter stud and a good ground. But, the charger needs to be connected the same as the battery. If the vehicle system is positive ground then the positive charger lead needs to go to ground.
Old 11-13-2014, 10:43 AM   #4
newshirt
newshirt's Avatar
I have a follow-up question about your lights and horn. Are the lights just dim when the motor is not running? And does the horn just growl rather than produce a full Ahooooga? Or do these not work at all when the engine is off?
If they are just diminished when the motor is off, then I suspect poor grounding or bad electrical connections. Have you checked them closely?
Ray White
newshirt is offline   Reply With Quote
Old 11-13-2014, 11:48 AM   #5
johnbuckley
johnbuckley's Avatar
Originally Posted by newshirt View Post
I have a follow-up question about your lights and horn. Are the lights just dim when the motor is not running? And does the horn just growl rather than produce a full Ahooooga? Or do these not work at all when the engine is off?If they are just diminished when the motor is off, then I suspect poor grounding or bad electrical connections. Have you checked them closely?
Suspect either a very low charge on battery, or if starter motor turns the engine well then like you I'd suspect poor earth or poor feed somewhere with those components
johnbuckley is offline   Reply With Quote
Old 11-13-2014, 11:49 AM   #6
Gary loves Fords
Thanks Ray, I meant to say positive on ground, rather than the other way.
Old 11-13-2014, 11:50 AM   #7
Gary loves Fords
I meant to say positive to ground instead of the other way around.
Old 11-13-2014, 11:51 AM   #8
Gary loves Fords
John, there is not power to the horn or lights when the motor is not running. They must have wired it differently than my previous A's.
Old 11-13-2014, 11:51 AM   #9
johnbuckley
With over the eigthy years of fettling the polarity can get changed on these old girls- I have useful info like postive or negative ground on a laminated sheet of paper under the drivers carpet.
Old 11-13-2014, 12:00 PM   #10
newshirt
newshirt's Avatar
Gary, do you have a schematic of the original Model A wiring? They are posted often here on fordbarn. I also carry a laminated copy.
You might consider checking your wiring against the original schematic, and possibly rewiring. That could aid in troubleshooting and roadside repairs. Other Model A owners could quickly isolate issues because of their familiarity with the original wiring. But if electricity is not your strong suit, this could be difficult and may get you into trouble. As they say... if it's not broke, don't fix it!
Ray White
Old 11-13-2014, 12:01 PM   #11
Bob C
On the lights and horn it sounds like the wires feeding them are hooked
to the generator side of the cut out instead of the battery side.
Bob
Old 11-13-2014, 12:01 PM   #12
Tom Wesenberg
Tom Wesenberg's Avatar
This would happen if they ran the horn/lights wire to the INPUT side of the cutout, rather than the correct OUTPUT side.
Old 11-13-2014, 12:11 PM   #13
johnbuckley
"car will not start" thread on page 2 of Ford Barn commenced 11/11/14 has a couple of thumbnails of the wiring diagram you need.
Old 11-13-2014, 12:12 PM   #14
Gary loves Fords
I'l check that out. Thanks for the replies guys. Gary
Old 11-13-2014, 12:22 PM   #15
Gary loves Fords
Thanks for the info. I made copies of both. Gary
Old 11-13-2014, 12:45 PM   #16
jmeckel
jmeckel's Avatar
Unless you are 100% sure of how your car is wired, use a volt meter to verify polarity first, or you can have a lot of issues including a destroyed charger and or battery. Or in a worse case scenario an explosion of the battery or fire. Take the few minutes to be sure. Any cheap meter will work as the engine should be off. Also take the time to verify your wiring and document any variation from the original diagram or change it back to original it will save a lot of time latter when something stops working. You will at least know what the "normal" state was.
Jon
"If you choose to not decide, you still have made a choice!" RUSH
Don't tell me what you know..... Tell me what you have done.
jmeckel is offline   Reply With Quote
Old 11-13-2014, 08:26 PM   #17
SteveB31
SteveB31's Avatar
I suspect that the wire that feeds the lights, that should be hooked to the output side of the cutout, is instead hooked to the generator side of the cutout. That would explain why the lights and horn ONLY work when the car is running. They only work after the cutout closes.
Something easy to look at.
SteveB31 is offline   Reply With Quote
Old 11-13-2014, 09:17 PM   #18
Y-Blockhead
Y-Blockhead's Avatar
Bob
Great minds think alike...
