Old 10-27-2014, 01:50 PM   #1
CP
CP's Avatar
Default how long do points last.
read here often and have not posted in quite some time. all has been going well. However, the last time I made the trip (300 mi ea way) to Vermont, she started running like crap the last 50 miles or so. Luckily I made it home ok.
I have yet to change the cap, rotor, plugs, points,,,,which I think will solve my issue...but I was wondering....
How many miles do you put on a flathead before you change the plugs, cap rotor, etc....? I have maybe 3000 miles on it since everything was "new".
Back in 1935....3000 miles was a long way no? so what do you think?
I have a Mallory elec ignition all new since rebuild but the old points were running sooo well...I never installed. now I'm thinking about what to do...
thanks, no worries...we'll figure it out. (winter is coming).
CP
CP is offline   Reply With Quote
Old 10-27-2014, 03:53 PM   #2
richard crow
Default Re: how long do points last.
back in the 50,s a tune up was points & plugs & cond. every 10,000 miles gen brushes 25,000. cap & roter were looked at if needed they were replaced
richard crow is offline   Reply With Quote
Old 10-27-2014, 04:11 PM   #3
George/Maine
George/Maine's Avatar
electronic ignition doesn't have the arcing like capacitive discharge ign.
Just the fiber wears down and just re adjust.
George/Maine is offline   Reply With Quote
Old 10-27-2014, 04:55 PM   #4
41ford1
41ford1's Avatar
So it started running like crap all of a sudden? Look at the simple things first. Loose wires and connections on the primary circuit including the condenser. Start at the coil and work your way back to the battery. Loose or shorted HT wires.
The condenser is high on the list of electrical failures. Replace that before doing a tune up.
You are never to old to enjoy your childhood.
Forty1fordpickup on the HAMB.
41ford1 is offline   Reply With Quote
Old 10-27-2014, 06:17 PM   #5
deuce_roadster
deuce_roadster's Avatar
In my opinion, point life is directly related to 2 things. Quality of the points, NOS best, nylon rubbing blocks worst, and how close the condenser mfd rating is compared to what it is supposed to be. When you have NOS points and the correct condenser--and it is set up on a machine you should get many thousands of miles on the points and condenser.
Old 10-27-2014, 07:32 PM   #6
rotorwrench
rotorwrench's Avatar
A good condenser is the key to a long lasting set of points. It's getting harder to find good condensers.
Old 10-27-2014, 07:41 PM   #7
Old Henry
Old Henry's Avatar
Ford recommended replacing points every 10,000 miles. That's what I do. Technically speaking, the first of the two points to open may never need replacing because it does not cut off the current and never arcs. Only the second point to open ever does that and is the only one that really "wears". My first points always look like new. But, since the points come in pairs I replace them both "just in case."
Old 10-27-2014, 08:26 PM   #8
Binx
As said by deuce roadster and rotorwrench, the balance of the condenser capacitance is the key to long-lived points if all other connections are normal.
http://www.dansmc.com/condenser_capacity.gif
Lonnie
Binx is offline   Reply With Quote
