Go Back   The Ford Barn > The Archives > Late V8
Old 01-01-1970, 12:00 AM   #1
Guest
Posts: n/a
Default 55 TBIRD Engine & Tranny...what do I have
Bought 55 bird recently and it's now clear to me that I don't have the original engine and trans in it....engine looks like a Y block...how do I confirm that? And what size and year it is? Tranny is a smooth shifting 3 spd, only it's causing the engine to run at >3k rpm at 65mph...not good. How do I identify what it is as well? Thinking the tranny at the very least needs to be replaced with something that can run at lower rpm's at 70mph.
<table><tr><td><font face="arial">
Old 01-01-1970, 12:00 AM   #2
Guest
Posts: n/a
Default Re: 55 TBIRD Engine & Tranny...what do I have
The trans is not making the engine run at high RPM's the rear end is what determines that. you proably have a high ratio rear end.
Old 01-01-1970, 12:00 AM   #3
Guest
Posts: n/a
Is the transmission a straight 3 speed or is it a 3 speed with overdrive? If it is an OD maybe it's not working (fuse, solinoid etc.).
Old 01-01-1970, 12:00 AM   #4
Guest
Posts: n/a
There is a Y-Block web site online with pictures that may help you out.I forget the address but it should come up on a search.Try Google,its a good searh engine.
Old 01-01-1970, 12:00 AM   #5
Guest
Posts: n/a
If It is a Y-Block you can tell buy the valve covers.First do the covers have 2 nuts on top at each end, if so it's a Y block, also do they have a decal that say's Thunderbird in white letters, if so it is a Y block.
Old 01-01-1970, 12:00 AM   #6
Guest
Posts: n/a
Go to www.ford-y-block.com for info on engine ID.
Since engines werent serialized you have to go by casting #. In 55 the T bird was available with a 272 or 292. Trannys were 3 sp; 3sp/OD and Fordomatic.
Old 01-01-1970, 12:00 AM   #7
Guest
Posts: n/a
Went to the site...the oil filter is not located where shown on the site...must not be a Y-block. The oil filter is at the front left of the block. The distributor is on the front left of the block. There are 6 bolts on the valve cover, three are on the bottom lip, 1 on each side, one on the top. Not being a Ford man, I still don't know what this engine is...will send you a picture for ID if you don't mind.
Old 01-01-1970, 12:00 AM   #8
Guest
Posts: n/a
Roger,
Look for some casting numbers on the engine or components. The number on the intake manifold is usually easy to see and will help identify the engine. Based on what you have said so far about the valve cover bolts and the distributor locat1on I would guess that it is a small block Ford. If you don’t want to keep the Y block in an early T-Bird (which is what I prefer to do) this is a good choice for an engine.
Charlie Stephens
Old 01-01-1970, 12:00 AM   #9
Guest
Posts: n/a
Sound like a 4:11 rear, might have an overdrive tranny.
Old 01-01-1970, 12:00 AM   #10
Guest
Posts: n/a
Sounds like you have either a 260, 289, 302 or 351 windsor.
Old 01-01-1970, 12:00 AM   #11
Guest
Posts: n/a
I agree, sounds like a SBF. Go here for ID on that family.
Sending me a pic is fine if you still need help.
I even stuffed a 389 Pontiac and tripower with Muncie in a 55 Bird back around 67. Went like stink!
Old 01-01-1970, 12:00 AM   #12
Guest
Posts: n/a
error correction...the distributor is on the front RIGHT (passenger side) of the block.
Old 01-01-1970, 12:00 AM   #13
Guest
Posts: n/a
Sorry about the missing link, senior moment brain fart!
http://www.cehighperformance.com/for..._car_codes.htm
From the pics it is a SBF but I dont know what you meant about the distributor locat1on. That looks drivers side to me.
