Go Back   The Ford Barn > The Archives > Late V8
Old 01-01-1970, 12:00 AM   #1
Guest
Posts: n/a
Default V8 intake manifolds
I am at home with the Model T, the Model A and early v8's and know little about late v8's. A friend is cleaning his garage. He brought me 3 intake manifolds he no longer needs. All 3 are aluminum and he thinks they fit the 260, 289 and the 302 from mid 60's to late 70's. Can anyone narrow this year spread down a bit? One is an Edelbrock # F4B, one is an Offenhauser # 360, and one is a Cobra and this one has 2 carburetors with linkage. I would like to get some idea of value. These are barn fresh and are not sanitary, but seem to have no physical damage. The carbs on the Cobra would be cores for rebuild.
<table><tr><td><font face="arial">
Old 01-01-1970, 12:00 AM   #2
Guest
Posts: n/a
Default Re: V8 intake manifolds
If they are all the same size and bolt pattern then they will all fit 221, 260, 289, and 302 from '62 thru now. Check on eBay, single 4 bble are going $75 to $150 average, the 2x4 is what the market will bare. Probably in the neighborhood of $250 to $350. By not seeing the real things, you have to keep in mind that this is only my guess-to-mates.
