Go Back   The Ford Barn > The Archives > Late V8
Old 01-01-1970, 12:00 AM   #1
Guest
Posts: n/a
Default 9 inch in a 54 sedan? What swaps in?
I am putting in a healthy engine in my 54 sled. I am afraid that the stock rear on my 54 2 door sedan will not be able to handle the abuse I plan to put to it. What year 9 inch will work to replace my current rear?
<table><tr><td><font face="arial">
Old 01-01-1970, 12:00 AM   #2
Guest
Posts: n/a
Default Re: 9 inch in a 54 sedan? What swaps in?
'57 thru '59 car and Lincoln Versallies (these have rear disc brakes).
Old 01-01-1970, 12:00 AM   #3
Guest
Posts: n/a
Bolt pattern and wheelbase are the same? Just want to make sure to keep it as close as I can for wheel clearence.
Old 01-01-1970, 12:00 AM   #4
Guest
Posts: n/a
These have the same bolt pattern and are within 1/2" +or- in width. I have a '57-'59 in my '54.
Old 01-01-1970, 12:00 AM   #5
Guest
Posts: n/a
Thank you very much!
Old 01-01-1970, 12:00 AM   #6
Guest
Posts: n/a
You can also use 66-70 mustang 9". 1/2 inch wider and need to move spring perches. Have a 69 rear in my 52 Vicky with 429 CJ.
