01-01-1970, 12:00 AM | #1 |
Guest
Posts: n/a
Backfire on Deceleration
My truck runs good until i take my foot off the accelerator which provokes many popps or backfire. Am i running lean, rich, or is it because of something else? <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #2 |
Guest
Posts: n/a
Re: Backfire on Deceleration
See if your exhaust is sucking in cold air in the manifold. <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #3 |
Guest
Posts: n/a
it usually means your running lean vaccuum leak i used to remove the vacuum line from the distributor on my chevy to make it do that <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #4 |
Guest
Posts: n/a
Hey, it worked on the Fords too. It sure would make them glasspacks "crack"!. <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #5 |
Guest
Posts: n/a
you have a vaccum leak in either the intake or exaust manifold <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #6 |
Guest
Posts: n/a
thats right...we spent serious money (mostly fines) in order to get that sound.. <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #7 |
Guest
Posts: n/a
all this about vacume leaks is very unlikely. it is usaly the deverter valve. block off the hse going to the exhaust and if it stops back firing then replace that deverter valve. some trucks have one for each side of the exhaust( v8's) <table><tr><td><font face="arial"> |
