Go Back   The Ford Barn > The Archives > Late V8
Old 01-01-1970, 12:00 AM   #1
Guest
Posts: n/a
Default granada rear
can anyone tell me what rear end late 70's granadas used and flange to flange width?Thanks in advance J.B.
<table><tr><td><font face="arial">
Old 01-01-1970, 12:00 AM   #2
Guest
Posts: n/a
Default Re: granada rear
Go to:
http://hiqties.hypermart.net/9inch.html
See if that helps.
Old 01-01-1970, 12:00 AM   #3
Guest
Posts: n/a
The granada used an 8 inch rear. I don't know the width.
Old 01-01-1970, 12:00 AM   #4
Guest
Posts: n/a
I'm afraid Hoss's memory is not what it used to be. The Granada/Monarch/Versailies disc brake rearend is a 9 inch and measures 58 1/2 inches from flange to flange. the 65-66 Mustangs are 57 5/8; the 67-70 are 60 and the 71-73 are 61. If you are plasnning a retro fit I'd advise going aftermarket instead. Unless you already have one bought and rebuilt ready to install the aftermarket units from Stainlees Steel or any number of other manufacturers are far superior in quality and performance and in the long run cheaper.
