Old 09-29-2014, 08:01 AM   #1
guy1unico
Default Books for axle / banjo rear removal
I have to remove the rear end on my 33 . Are there any good books that show a step by step process?
guy1unico is offline   Reply With Quote
Old 09-29-2014, 02:43 PM   #2
A bones
A bones's Avatar
Default Re: Books for axle / banjo rear removal
Have you seen the thread that ends 09/26/14 10:29? Not a step by step, but....it does hit the high spots. good luck Tom
A bones is offline   Reply With Quote
Old 09-29-2014, 04:07 PM   #3
Zeke...PA
Zeke...PA's Avatar
Try Les Andrews Model A Ford Mechanics Handbook rears are similar. Zeke
Only problem with retirement is never a day off
Zeke...PA is offline   Reply With Quote
Old 09-29-2014, 07:14 PM   #4
flat-v8
flat-v8's Avatar
I have a couple in MS word format that I used, helped alot! They are too big to post here but I could email to you, PM me with email address if interested.
flat-v8 is offline   Reply With Quote
Old 09-29-2014, 08:39 PM   #5
supereal
supereal's Avatar
The best all around shop manual for the novice mechanic is the Canadian book. Ford didn't produce a shop manual until the "new" Ford arrived in 1949. The Canadian book is available from a vendor such as C&G.
supereal is offline   Reply With Quote
Old 09-29-2014, 08:53 PM   #6
Bruce Lancaster
Some '33-4 specs differ from later...this rear is covered in the '33 service bulletins, and overhauls stuff was included in '38 bulletins too. If you don't have at least the early bulletins you are working in the dark...they are a basic tool.
Another good book is the reprint of the old NAPA shop manual for '32-6...C&G calls the current edition:V-13
Repair Manual
32-36 Passenger & Pickup
R&R of the assembly isn't covered specifically but is fairly obvious, spring . brake rods, U-joint cover, etc.
Procedures are very similar for all the early rears, but there are differences and different specs for things like pinion preload...the families are '28-32, late '32-34, and '35-48. All are very well covered in the bulletins.
Bruce Lancaster is offline   Reply With Quote
