Old 09-27-2014, 08:19 PM   #1
joe 1950
joe 1950's Avatar
Default 6 volt or 12 volt conversion
1950 ford with a good 6 volt system its time to replace my battery but ive ben thinking about a conversion to 12 volts for better lights and alternator charging system I know its not that hard to do with the reducers for the gauges good idea or bad need some input
joe 1950 is offline   Reply With Quote
Old 09-27-2014, 08:45 PM   #2
Planojc
Planojc's Avatar
Default Re: 6 volt or 12 volt conversion
After putting a 6volt alternator on my 51, I see no need to go 12 volts. The lights are much better and my overdrive never fails to kick in.
Planojc is offline   Reply With Quote
Old 09-27-2014, 11:16 PM   #3
slowforty
Usually with six volts if ALL of your Connections and Grounds are good you wont have any problems.{good conections,Proper size wire}
slowforty is offline   Reply With Quote
Old 09-27-2014, 11:44 PM   #4
19Fordy
19Fordy's Avatar
If it's already running fine on 6V no need to change to 12V.
Old 09-28-2014, 01:38 AM   #5
Fibber Mcgee
Fibber Mcgee's Avatar
I have one of each and if you have good connections and wires it really isn't worth the investment ,unless you plan on adding alot of 12 volt accessories.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
Old 09-28-2014, 12:25 PM   #6
George49Ford
George49Ford's Avatar
I rewired my '49 6 years ago, but left it 6 volt. Everything works perfectly.
George49Ford is offline   Reply With Quote
Old 09-28-2014, 05:01 PM   #7
gary635g
gary635g's Avatar
Mine is 6 volt and works fine.
gary635g is offline   Reply With Quote
Old 09-28-2014, 06:36 PM   #8
42guy
42guy's Avatar
Mine has been 6 volt for 72 years . I haven't owned that long but I am old enough. I have replaced headlight wiring and ample grounds wires. Never been a problem
42guy is offline   Reply With Quote
Old 09-28-2014, 07:49 PM   #9
joe 1950
joe 1950's Avatar
my 6volt system works 100 percent I have the big cables like suggested the only reason for the 12 volt conversion is for brighter tail and stop lights if you use hand signals now days people think your waving at them
Old 09-28-2014, 10:12 PM   #10
Bruno
Good connections, heavy cabling, a 1 wire alternator and a Brakelighter stop light in rear window make my 6 volt system function just fine for me!!!! Have a 12 volt neg. grd. radio mounted in glove box but it is wired thru an inverter - works fine.
Bruno is offline   Reply With Quote
Old 09-29-2014, 07:23 AM   #11
GreenMonster48
GreenMonster48's Avatar
I have 12 volt now. I'll never go back to 6.
GreenMonster48 is offline   Reply With Quote
Old 09-29-2014, 07:59 AM   #12
rockfla
rockfla's Avatar
Can we STOP the myth that 12V systems give you "BRIGHTER" lights. IF both 6V and 12V systems are working "PROPERLY" they will BOTH have bright lights!!! Face the facts, the MAIN reason that auto manufactures went to 12V systems was "ECONOMY", half the diameter wire required per car, same selling price=PROFIT.
