Old 09-23-2014, 09:19 PM   #1
38Tudor
38Tudor's Avatar
Default Fiber or Aluminum
I'm looking into changing my timing (cam/crank) gears. I've seen fiber and aluminum. Which type is recommended? Pros and cons.
Thanks.
"Thrifty Sixty"
Ford V8 for 1938
38Tudor is offline   Reply With Quote
Old 09-23-2014, 09:31 PM   #2
Richard in Florida
Richard in Florida's Avatar
Default Re: Fiber or Aluminum
Thanks.
Aluminum will last longer but it's noisier than fiber.
Richard in Florida is offline   Reply With Quote
Old 09-23-2014, 09:55 PM   #3
flatjack9
flatjack9's Avatar
I seriously doubt if you would be able to hear the difference. Go aluminum.
Old 09-23-2014, 10:13 PM   #4
JM 35 Sedan
JM 35 Sedan's Avatar
I went with an aluminum press on timing gear after a repro fiber gear failed in about 1500 miles. I don't hear any noticable difference in noise, but then my hearing is not all that good . The good news is that aluminum gear has given me 20k+ trouble free miles and still going. I would recommend going aluminum on the timing gear. Why are you thinking about replacing the crank gear?
John
Old 09-23-2014, 10:33 PM   #5
38Tudor
38Tudor's Avatar
I don't know. I just figured I will change both while I'm in there.
I have a bad whining sound going on. As heard in this video.
https://drive.google.com/file/d/0B-y...it?usp=sharing
"Thrifty Sixty"
Ford V8 for 1938
Old 09-23-2014, 10:50 PM   #6
Henry/Kokomo
Henry/Kokomo's Avatar
I'd check the condition of the crank gear before I made the decision to replace or not. Would definitely go with the aluminum gear.
I played the video. Does the car make the same whining noise when not in motion?
Henry
Henry/Kokomo is offline   Reply With Quote
Old 09-23-2014, 11:08 PM   #7
WestCoast
go aluminum, I doubt if you can find an American made fiber cam gear, the Chinese stuff is worse than junk, they become oil soaked quick and soften and loose teeth off the gear
WestCoast is offline   Reply With Quote
Old 09-24-2014, 02:48 AM   #8
49r
Aluminum works for me. Slightly noisier at idle, but doesn't sound out of place.
49r is offline   Reply With Quote
Old 09-24-2014, 06:11 AM   #9
38Tudor
38Tudor's Avatar
Yes same noise parked and with the fan belt off
"Thrifty Sixty"
Ford V8 for 1938
Old 09-24-2014, 06:41 AM   #10
jimTN
Alumn only. the fiber gears sold today are defective and will come apart.
jimTN is offline   Reply With Quote
Old 09-24-2014, 12:49 PM   #11
hardtimes
hardtimes's Avatar
Thanks.
You will hear..but their nosier , but do not believe it , as old wives tale !
Maybe you would / should check out a guy named Dan Mc Eachern. He MAKES gears, and they are like jewelry ! He makes the cam and crank gears matched ! He makes the crank gear of steel not iron ! And, he makes a bronze cam gear with matching crank gear(what I got).
I run aluminum, NO noise. I kinda wish and expected that there would be noise ...it's a guy thing,eh
BTW..when running gears straight cut, yeah expect noise. But most today are not made that way.
hardtimes is offline   Reply With Quote
Old 09-24-2014, 01:28 PM   #12
Ol' Ron
Ol' Ron's Avatar
Never saw a bad crank gear. Wouldn't know how to remove on in the engine.
Old 09-24-2014, 04:24 PM   #13
supereal
supereal's Avatar
If the noise is present with the belt off, but changes pitch as the engine speed is changed, I'd check the clutch pedal free play to be sure the noise isn't coming from the release bearing. You need at least an inch of free play
supereal is offline   Reply With Quote
Old 09-25-2014, 08:37 AM   #14
36tbird
Another thought while you're in there: take out the galley plug and drill a .046" hole or so for oil to spray the back side of the gears. I think I saw this in one of the Aussie rebuild books and I did it on my 8BA. With that, I still have 50 pounds of pressure running down the road with 40 wt. and M19.
36tbird is offline   Reply With Quote
Old 09-25-2014, 09:31 AM   #15
rhpope
Does anyone still sell new aluminum press on gears or do you just have to search and hope to find a good used one or a NOS one?
rhpope is offline   Reply With Quote
