Old 09-22-2014, 01:26 PM   #1
Uncle Bob
Uncle Bob's Avatar
Default 1932 sedan roof repair
Okay, looking for some advice from any who have "been there, done that..."
The stamped channel around the roof opening on my sedan project is eaten away in the corners, photo of the worst corner attached. Does someone out there make a replacement for this stamped section? Any other solution suggestions? I would prefer to continue with the fabric insert rather than do one of those steel filler panels. The wood will be replaced during the process.
TIA
Luck occurs when preparation and opportunity converge.
Uncle Bob is offline   Reply With Quote
Old 09-22-2014, 09:18 PM   #2
jerseyboy
jerseyboy's Avatar
Default Re: 1932 sedan roof repair
Bob,
Check out this thread:
http://www.fordbarn.com/forum/showth...ht=fordor+roof
Keep V-8ing and 4-banging!
She just don't have the appetite
For gas somehow,
And Dad, I got four carburetors
Hooked up on it now.
I tried to hook another
To see if I'd do a little good,
But ain't no place to put it
'Less I perforate the hood.
Wanted, lower side sections of 32 radiator cowl.
jerseyboy is offline   Reply With Quote
Old 09-23-2014, 08:32 AM   #3
Uncle Bob
Uncle Bob's Avatar
Originally Posted by jerseyboy View Post
Bob,
Yeah, I saw that one, and the info will be good for the tack strip/retainer, but I'm looking for a solution for the roof flange itself.
Old 09-23-2014, 02:37 PM   #4
supereal
supereal's Avatar
The flange can be mended with a steady hand and a wire welder. You can also back up the damaged portions with a wood piece held in place under the flange by screws thru good holes in the flange next to the ends of the piece.. This will allow plenty of hold for the tacks.
supereal is offline   Reply With Quote
Old 09-23-2014, 11:06 PM   #5
BoxCar Tom
BoxCar Tom's Avatar
That is grim! I would place a Want Ad on the Ford Barn Swap Meet for a patch panel, you need a cut out from an derelict. OR, hand form a patch using a bead roller. Doesn't have to be perfect since it is out of sight when completed.
BoxCar Tom is offline   Reply With Quote
