Old 09-21-2014, 12:14 PM   #1
Init1
Init1's Avatar
Default long rear spring U bolts.
Which year or model has the longest rear spring U bolts that will fit a 30 Model A rear cross member?
Init1 is offline   Reply With Quote
Old 09-21-2014, 05:01 PM   #2
texas webb
Default Re: long rear spring U bolts.
Do you have a stock spring? Snyders,Brattons or Macs should have what you need.
texas webb is offline   Reply With Quote
Old 09-22-2014, 03:50 PM   #3
Dave/Green Bay
Part no Type A B C Thread size No. Model Year
40 5705 11 2.88” 5.24” .88” 9/16”-18 2 Pass 33-34
78 5705-a 11 2.88” 4.88” 1.12” 9/16”-18 2 Pass & Comm 28-41
78 5705-b 11 2.88” 5.14” 1.12” 9/16”-18 2 Pass & Comm 28-37
78 5705-c 11 2.88” 3.97” 1.12” 9/16”-18 2 Pass & Comm 28-41
A = width ID
B = Inside Height
C = Thread length
Dave/Green Bay is offline   Reply With Quote
Old 09-22-2014, 05:29 PM   #4
Kube
Super Moderator
Kube's Avatar
Not certian why you want this information but am guessing a non-stock application. Yes?
You may or may not realize that just about every place that makes springs also makes "u-bolts". You can get them to your specification and quite reasonable at that...
Old 09-22-2014, 07:08 PM   #5
russcc
The green bible has all the specs also, defined as Dave/Green Bay showed in his post.
russcc is offline   Reply With Quote
