View Poll Results: Whats your favorite bore size using a 4 inch merc crankshaft
stock just hone 1 1.61%
255-3.188 5 8.06%
276-3.313 44 70.97%
286-3.375 7 11.29%
other 5 8.06%
Multiple Choice Poll. Voters: 62. You may not vote on this poll
Old 09-19-2014, 09:51 AM   #1
1934calkid
1934calkid's Avatar
Default Flathead Bore Size ?
This is for a street rod,34 coupe, flathead 8BA bore size favorite !
1934calkid is offline   Reply With Quote
Old 09-19-2014, 09:55 AM   #2
JWL
Default Re: Flathead Bore Size ?
+.030, .060, .080 or .125. Just wherever it will clean up.
JWL is offline   Reply With Quote
Old 09-19-2014, 10:08 AM   #3
deuce_roadster
deuce_roadster's Avatar
It is determined more by block condition then your wishes/favorite size.
Old 09-19-2014, 11:14 AM   #4
rotorwrench
rotorwrench's Avatar
If you want to bore one from standard all the way out to max, you will lose a lot of potential use of the block. If you are already at 3 5/16" then that is a good size for a hot rod. A person can go to sleeves though and use larger if you have a mind to. It just depends on how much you want to spend and how long you want it to last.
Old 09-19-2014, 11:48 AM   #5
tubman
tubman's Avatar
I did my first a 3 5/16 (276 with a Merc crank) and it worked well. I just bought another set of 3 5/16 pistons (this time for a stock stroke). Pistons, rings, and pins were $100, which is a heck of a lot less than a merc crank (if you can find one) for a comparable increase in displacement.
Old 09-19-2014, 12:43 PM   #6
OLD...BILL
OLD...BILL's Avatar
I'am at 3-5/16 with my build and one four inch merc. crank. 276 inch ?? at my age (82) I saved some for the next build ....?? and here I sit with two more complete engines with 59 on the bell ... I just like saving some for the next build or the next guy, and a JWL says just what it take to clean it up ?? Yes the grandkids will have a big yard sale someday ??......OLD.....BILL
OLD...BILL is offline   Reply With Quote
Old 09-19-2014, 02:56 PM   #7
Mike51Merc
Mike51Merc's Avatar
255 is stock with a 4 inch crank.
Mike51Merc is offline   Reply With Quote
Old 09-19-2014, 04:00 PM   #8
texas webb
Well I have a 51 merc eng(255 stock for now)for my Av8.May go a bit over in the future.
texas webb is offline   Reply With Quote
Old 09-19-2014, 04:02 PM   #9
Seth Swoboda
Seth Swoboda's Avatar
I agree with JWL.
Seth Swoboda is offline   Reply With Quote
Old 09-19-2014, 08:08 PM   #10
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
I like 276, 1/8'' bore. If you wear that bore out they make ,030 over 3-5/16 and probably .040 and .060 Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 09-19-2014, 08:11 PM   #11
Walt Dupont--Me.
Tubman, where did you get 3-5/16 pistons and rings for $100.00 Walt
Old 09-19-2014, 10:32 PM   #12
Ol' Ron
Ol' Ron's Avatar
Egge makes light 3 ring piston in 3 5/16, + .020 and .030. With the thin Metric rings. Saved a 276 with the .020" and rings from a Volvo truck. I now have a 280 (279.4) Milled EAB heads 8.2CR and a stock EAB cam. Talk about torque??? I think even JWL would like it.
Old 09-19-2014, 11:56 PM   #13
Ralph Moore
Ralph Moore's Avatar
I've got a 265 by my calculations, I just think, why bore it bigger than you have to, after all they aren't making them anymore.
Ralph Moore is offline   Reply With Quote
Old 09-20-2014, 01:36 AM   #14
tubman
tubman's Avatar
Speedway's garage sale section. About a year ago thay had a lot of piston sets (some were advertized as being made by Offenhauser) on closeout. I posted it here and on the H.A.M.B. The pistons came in a "plain brown wrapper", so they may be Chinese. but I took a chance on them. They look real nice and I went over them with a mic and all appears well. We shall see.
(Edit : Just for kicks, I checked the Garage Sale page again; there are still a few sets of pistons, but the prices I paid are long gone,)
Old 09-20-2014, 08:15 AM   #15
Tony, NY
That's what I have too.
Tony, NY is offline   Reply With Quote
Old 09-20-2014, 09:01 AM   #16
rotorwrench
Speedway had some hypereutectic flathead pistons for a while that were cast for them. They must not have sold too well but I haven't really heard anything about how they worked out. It would be interesting to know. I always wondered why the piston makers didn't go that route. The expansion factors for those pistons allow for a tighter bore clearance than with forged ones. The cost might be prohibitive in a niche market. How strong they are would be the big question for me.
Old 09-20-2014, 12:32 PM   #17
Old Ford Addict
Old Ford Addict's Avatar
Flathead bores are tougher than some of you give them credit for … part of the reason there still here.
The truth is you’d have a hard time wearing one to the point of needing a rebore in the time any of you have left.
Bore it out all the way ... you cant take it with ya
Old Ford Addict is offline   Reply With Quote
Old 09-20-2014, 01:35 PM   #18
1934calkid
1934calkid's Avatar
The main question was WHAT IS YOUR FAVORITE BORE SIZE FOR A STREET ROD ...
Old 09-20-2014, 03:01 PM   #19
OLD...BILL
OLD...BILL's Avatar
Hey Calkid; looks like you got your answer 3-5/16...276, hands down, or 75 per/cent .........not good enough for you, ?? all this talk about it, make me want to do it again, all I need is someone to make the "HOLE"
And find me a pieeeekup 39 or 40 I'll do it........OLD.....BILL
Old 09-20-2014, 03:05 PM   #20
37fordtruckguy
37fordtruckguy's Avatar
3 3/8
37fordtruckguy is offline   Reply With Quote
