Old 09-11-2014, 07:18 PM   #1
malloyjp
Default What the Dwell ?
I recently put new points in my distributor and set the gap to what I thought was the correct gap, but the dwell meter is reading low. It's reading 24 , and the correct dwell is supposed to be 29 per the manual. The car is running good though. I'm confused because the points that I replaced were really shot, but the dwell meter was reading spot on at 29 with the bad points.
How can I get the dwell setting correct ? I know a low reading indicates the gap should be less , but I'm not sure how to adjust because the gap seemed correct .
It's a 69 mustang mach1 with 351 windsor and original autolite distributor. Thanks !
malloyjp is offline   Reply With Quote
