Old 08-30-2014, 09:49 PM   #1
DD931
DD931's Avatar
Default Generator ID
I just overhauled the generator for my '48 F-1. The case is stamped with a Ford script followed by C-2. I also have a core I picked up somewhere that I plan to overhaul as a spare. I assume it's from a car, because it has a narrow belt pulley. No idea where it actually came from. In every other respect it seems exactly like the one on my truck, except the number on the case after the Ford logo is 9-1-1. Does anyone know what these numbers mean?
DD931 is offline   Reply With Quote
Old 08-31-2014, 05:43 AM   #2
Terry,OH
Terry,OH's Avatar
Default Re: Generator ID
They are a date code. Ford had been marking the body of the generator and the starter with the code for a long time. Model A, all the early V8. At some point the code had to change (run through the alphabet). For the early pre war V8 the letter is for the year and the number for the month. Such as:
1931=L , 36=Q, 41=V
32=M, 37=R, 42=W
33=N, 38=S
34=O, 39=T
35=P, 40=U
1=Jan. to 12=Dec.
Old 08-31-2014, 09:32 AM   #3
DD931
DD931's Avatar
Terry - Thanks! That makes perfect sense for the C-2 stamp (Feb '48). Do you have any thoughts about the 9-1-1?
Old 08-31-2014, 09:58 AM   #4
V8COOPMAN
V8COOPMAN's Avatar
Hmmmm.......that 9-1-1 would seem to be the perfect candidate to overhaul and keep on the shelf for "emergencies". DD
Click Links Below __
T5 W/TORQUE TUBE
Old 08-31-2014, 12:16 PM   #5
DD931
DD931's Avatar
Yes, I thought of that!!
