#1 |
Did Ford have an instruction manual on the proper way to fold the power top down?
Does anyone have a copy of it? Where should the top/irons be when down , level or slightly above the deck? I bought a boot cover from one of the main suppliers that is for my 47 but is too tight & does not cover the corners well. It is suppose to be the right one , so thinking I may be doing something wrong with the top as I am folding it down. Thanks |
#2 |
Are you folding the top by hand or is the automatic system hooked up? Sometimes it is necessary to push down on the top side irons, to be able to snap the boot in place. The top material should fold between the top bows, and the header bow should rest just above the rear deck when in the lowered position. Ford did have instruction manuals for top operation, with the manual tops, not sure about the 'power' tops.
#3 |
Ive tried everything I can think of to fold the top on our 47. Every way seems to be wrong, and the boot does not want to go on.
#4 |
I bought a boot from Mac's for my '48 and was also too short to reach the corners. Sent it back with instructions to add 2 1/2" length in center and that solved the problem. No charge for alteration including shipping.
#5 |
You MUST unsnap the buttons on each side or ripppppppppppppp! Originally there was breakaway snaps but they do not seem to be existant today.
#6 |
#7 |
You say the snaps are available then you repeat my warning about unsnaping before lowering. Are you talking about two different things? I would sure like to have some of those automatic release snaps for the outside corners and I believe (some time ago) I called LB and they did not know what I was referring to.
#8 |
My top, plus snaps, plus boot, all came from LB, about 14 yrs ago. Snaps are not anything special, and overall fit of top and boot is only so-so. It's only adequate.
#9 |
I have them on my 49. The male snap snaps into a channel and when the top is lowered they slide out to release. I am able to pull the material out between the bows and fold it over the irons. It let's it go down further and is less wrinkled when I put it up. I am guessing the top quality Haartz cloth we use today is much heavier than original.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
#10 |
My L-B catalog lists two types of "self releasing fasteners". Item 10326 for 1940, 10332 for '41-'48. I looked up mine, and they were $3.95 each then. I add that I wouldn't depend on them to release, but installed them to be correct. I always unsnap all by hand before lowering the top. The order takers at many vendors don't have a clue as to what they are selling unless you can give them a stock number. I fought that battle with a vendor that shall remain nameless here, I ordered a set of the running board trims for my '47. When it arrived, both fit the left side only. They said they were the same for both sides, which is not true. They told me to send them back, and they would send another set. You guessed it. The new set was for the right side only! Never ordered from them ever again.
#11 |
Thanks for all the information .. the power top is in operation , I use it & assist manually as well.
Appears there has been top boot size issues with different companies. Attached are some pictures with the top down , does this look low enough? If so I will get the boot modified. Thanks |
