Go Back   The Ford Barn > The Archives > Model-T
Old 01-01-1970, 12:00 AM   #1
Guest
Posts: n/a
Default Using the magneto to charge a battery
I have been thinking on this a while - I wonder if there's some way to use the current from the T mag to charge a 6 (or 12) volt battery?
The reason I ask is this - a battery charger takes house current (117 vac), rectifys it, regulates the voltage, and charges a battery.
From what I read, the T mag puts out 6-17 vac, at enough current to buzz the coils and run the lights.
So my question is this - why couldn't someone rectify the output of a T mag (on a separate wire from the one to the coilbox), put a regulator on it, and use it to charge, say, a 6V Storage Battery? Has anyone done or tried this? Is there something really simple here I'm missing? Why hasn't this been done before?
I had to put an electric bulb in my taillight (yeech!) and hook up a switch for a brake light (to make it OK with California) I worry the battery I'm useing it off of will die and leave me in the dark some night. Any ideas are welcome!
Thanx,
Susanne
Old 01-01-1970, 12:00 AM   #2
Guest
Posts: n/a
Default Re: Using the magneto to charge a battery
Susanne
This can easily be done, but I strongly suggest you buy a proven kit to avoid damage to the magneto. www.funprojects.com sells a kit you can use for charging the battery from the magneto. It is designed in such a way to that should the diode fail the amount of dc current flowing back into the field winding will not demagnetize the magnets.
Coilman
