Old 08-06-2014, 05:55 PM   #1
Tom Wesenberg
Tom Wesenberg's Avatar
Default How Do You Date Spark Plugs
At the last swap meet I bought 4 AC spark plugs mainly because they were only a buck each and NOS in the box. They are number 83 SPECIAL, 18 MM thread and 7/8 Hex. I was wondering what time period they were made and what they fit? I know they fit the Model A, but don't know if they are correct for it. The last patent on the AC box is 2,272,338.
What's really unusual is they are sealed in cosmoline, so I'm not sure if I should open one up.
The small Autolite plug is PR-4 10 MM resistor. I know Chevrolet used a small thread for a short period in the 40's, but don't know if this plug would be correct for them.
Plugs change shape on the porcelain every so often, and I'd like to find a chart or pictures to show when these and other plugs might have been made. Does anyone know of a site with such information, or a good book on spark plugs? Thanks.
Old 08-06-2014, 06:09 PM   #2
Mitch//pa
Default Re: How Do You Date Spark Plugs
did you do a patent search for the time period?
Old 08-06-2014, 06:22 PM   #3
gwhite
gwhite's Avatar
From my experience, the patent search won't help much...
Sometimes the boxes have printing dates on them...I've got a set of Champions that have 4-41 printed on the boxes.
Another good method is to look at advertising, for instance, Champion advertising shows plugs with brass tops from 1935-41;
The brass top evidently went away by 1942 as evidenced in this ad;
In 1948, advertising shows a different insulator (different ribbing);
gwhite is offline   Reply With Quote
Old 08-06-2014, 06:25 PM   #4
Mitch//pa
the patent search i did came up with 1935
Old 08-06-2014, 06:46 PM   #5
Tom Wesenberg
Mitch, I've never done a patent search, so may have to try it.
gwhite, sure glad you posted those pictures because the second and third Champions are the exact plugs I was trying to research yesterday, and had no luck.
Old 08-06-2014, 06:48 PM   #6
Roadster62
Roadster62's Avatar
As a rule of thumb anything packed in cosmoline is a WWII surplus item. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 08-06-2014, 06:50 PM   #7
Tom Wesenberg
That's what I was thinking, as the only things I've seen packed in cosmoline have been for the military.
Old 08-07-2014, 12:10 AM   #8
700rpm
700rpm's Avatar
I dated a real spark plug in college. She was easy to date: I just asked. Manufactured about 1945, but she still ran hot in 1965.
Ray Horton, Portland, OR
Old 08-07-2014, 07:23 AM   #9
emf
emf's Avatar
I know I'm new to A's, but 18 mm plugs don't fit my head....
Frank
emf is offline   Reply With Quote
Old 08-07-2014, 09:39 AM   #10
steve s
steve s's Avatar
I understand that you can find any kind of date you want on Craig's List.
steve s is offline   Reply With Quote
Old 08-07-2014, 09:53 AM   #11
Big John
emf....i take it, it is not for your head, but for your a's lol Big John
Big John is offline   Reply With Quote
Old 08-07-2014, 10:01 AM   #12
GrandpasA
GrandpasA's Avatar
I like your style.. I was thinking on these lines as well when I saw the title to this thread..
I only date hot spark plugs...
GrandpasA is offline   Reply With Quote
Old 08-07-2014, 10:27 AM   #13
gwhite
gwhite's Avatar
Hey fellas, my apologies for the poor photo of the 1948-up plugs...here is a better one (this from a 1948 Canadian ad);
And a scan from a 1938 Champion catalog (shows the brass top design). Note: 14mm plugs such as the J8 shown below appear to have not used the brass top.
Here's the set of NOS Champion brass tops I picked up for my Winfield-powered "hot rod";
Old 08-07-2014, 08:00 PM   #14
redmodelt
redmodelt's Avatar
Them sparking plugs like live wires! Keeps them feeling young and alive.
Old 08-07-2014, 08:10 PM   #15
GrandpasA
GrandpasA's Avatar
now thats funny and true..
Old 08-07-2014, 08:19 PM   #16
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Ray, you a dirty old man! And, did this "SPARK PLUG" chick have an expiration date, or does that apply to SPARK PLUGS?
I cooked 2 Lbs of low fat hamburger from Gregg's freezer, dated, 7-29-2010! Cooked a test patty & gave the Dog a bite he smiled & I ate the rest. We had taco/burrito meat for a week, it was DELICIOUS!
Gettin' back to spark plugs, Vermin has like new Champion C-16-C's--Wunder how old they are? Engine was built in '87 & barely run. His 6:00 X 16 Firestones still had nubbies on the tread, but the sidewalls were ROTTEN, but the tubes held air for 3 years
My point is, should we keep our spark plugs & tires & tubes in a FREEZER?
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 08-08-2014, 12:37 PM   #17
Tom Wesenberg
Frank
You are right emf.
I think I have a loose solder connection in one of my brain cells.
Old 08-08-2014, 12:57 PM   #18
gwhite
gwhite's Avatar
Frank
They fit mine (Winfield head)
Old 08-08-2014, 09:51 PM   #19
19ED30
19ED30's Avatar
Gwhit , is your Fuel Delivery set up a type of Mechanical Injection?
19ED30 is offline   Reply With Quote
Old 08-09-2014, 06:50 AM   #20
gwhite
gwhite's Avatar
No, it's a early 1930's Winfield SR-B carburetor. The only challenge I have with this combination is getting fuel to it (no fuel pump on the A motor and it's got a '27 roadster body on it, so gravity feed won't work). As my goal was a true period-correct late 30's-early 40's hot rod, I ended up using a hand pump from a '22 Cadillac to pressurize the fuel tank.
Carb;
Hand pump;
Pressure gauge (from a 1918 Dodge);
To maintain pressure in the tank, I needed a non-vented gas cap...I lucked out and found this '22 Cadillac cap; it's got a neat pressure release valve built in (the T-shaped bolt threads into the cap and puts pressure on the steel disc and leather seal);
Sorry for all the non-stock discussion.
