07-31-2014, 03:27 AM | #1 |
fendor welting and fendor bolts
Is it right in assuming that holes have to be cut in the welting to pass the fendor bolts through?
07-31-2014, 04:00 AM | #2 |
Re: fendor welting and fendor bolts
Yes, that is correct.
07-31-2014, 07:06 AM | #3 |
Frank
If you notch the fender bolt holes in the welting . The welting can slide between fender & body allowing adjustment to placement of the welting. Hope this helps Bill |
07-31-2014, 08:03 AM | #4 |
