Old 07-22-2014, 08:51 PM   #1
fordf1trucknut
Default New 23 t owner in southwest pa
After recently picking up a nice model a coupe and enjoying it. We decided to add a model t touring car to the stable.
I took it for our maiden voyage today. My 1 and 5 year old loved it (wife was at work so she hasn't ridden in it yet) my 5 year old daughter said she likes it as much as the model a.
fordf1trucknut is offline   Reply With Quote
Old 07-23-2014, 07:12 AM   #2
Will N
Will N's Avatar
Default Re: New 23 t owner in southwest pa
Nothing like haveing a little T and A, I always say!
Will N is offline   Reply With Quote
Old 07-23-2014, 03:52 PM   #3
Big John
VEEEEERRRRRY NEAT......NICE COMBINATION WITH ALL BLACK< CREAM WIRE WHEELS>>>NICE BUY>>>Big John
Big John is offline   Reply With Quote
Old 07-24-2014, 12:18 PM   #4
fordf1trucknut
Thanks.
So far I added a stoplight by using a 27 style brake switch and dual filament socket. And discovered that the amp meter was wired backwards. I also found that the generator cutout was sticking. So I ordered a new one of those as well. I also have a new interstate battery on the way. Since the old one is a bit weak.
Old 07-25-2014, 12:17 PM   #5
Willie in Houston
Willie in Houston's Avatar
Just a thought. Model T fords used a negative ground systems and Model A fords used a positive ground system. That may be why you thought the amp meter was wired backward?????
Willie in Houston is offline   Reply With Quote
Old 07-25-2014, 05:23 PM   #6
fordf1trucknut
Yeah. I have it hooked up negative ground.
Old 07-27-2014, 10:07 PM   #7
fordf1trucknut
The new cutout works as it should and it seems to be running well.
I look forward to putting a lot of miles on it.
