Old 07-15-2014, 06:29 AM   #1
slackcat
slackcat's Avatar
Default YIPPEE!!! Started engine replacement!!
Have the A in the shop and started removing last night. Spent last winter looking for an engine, got sidetracked by a T speedster, and found an engine last May.
Two questions:
1. How to remove GAV/choke rod.
2. What to look out for when seperating engine from tranny.
Pretty stoked to get the A back on the road.
slackcat is offline   Reply With Quote
Old 07-15-2014, 07:05 AM   #2
Gunmetal blue2
Gunmetal blue2's Avatar
Default Re: YIPPEE!!! Started engine replacement!!
Pull up on metal sleeve on rod under the hood. you will see the rods are offset each other, seperate them and it come apart. In the red box.
Gunmetal blue2 is offline   Reply With Quote
Old 07-15-2014, 07:41 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Don't force anything when you try to seperate the engine from the tranny. Make sure ALL the bolts have been removed. I've read a couple of broken parts threads when a bolt was missed.
Be sure to remove the throttle cross linkage first, and install it last, so it doesn't get damaged or mess up the firewall paint.
Old 07-15-2014, 07:51 AM   #4
Mitch//pa
exciting isnt it.
Old 07-15-2014, 01:04 PM   #5
slackcat
slackcat's Avatar
Thanks for the info Gunmetal and Tom. Radiator coming out tonight and if time allows the engine. Just have to remove the cross linkage, tranny bolts, and unbolt from frame. Unhooked the GAV/choke this morning.
Old 07-16-2014, 07:06 AM   #6
slackcat
slackcat's Avatar
Had a good evening last night. Son and I have the engine out and ready to transfer carb and clutch. Input shaft looks to be way over engineered, huge for the HP. Really love the mechanics of these cars. I'm lucky that the car had a frame-off many years ago so no need to replace parts as we go and real clean.
Will be checking tranny fluid level and wondering what weight of oil to use if needed.
Old 07-19-2014, 08:28 AM   #7
slackcat
slackcat's Avatar
Engine istalled and wired last night. The inlaws invited themselves over for dinner again last night so didn't get started until after 9, but was productive. Oh, I'd like to thank the person who invented the engine leveler.
Old 11-04-2014, 05:31 AM   #8
slackcat
slackcat's Avatar
Work and family have kept me busier than a cat covering crap on a marble floor but thankfully my car is back on the road. The tail/brake light thread has been a good read and looks to be a good winter upgrade along with some 16" wire wheels.
1929 A Special Coupe
1926 T Speedster
Old 11-04-2014, 05:38 AM   #9
C26Pinelake
Congratulations on your accomplishments. Hopefully the inlaws will come over when it's time to go to the gas station ( lol ) !
Wayne
C26Pinelake is offline   Reply With Quote
Old 11-04-2014, 06:05 AM   #10
slackcat
slackcat's Avatar
Hopefully thr inlays will come over when it's time to go to the gas station
( lol ) !
Wayne
I wish!!
1926 T Speedster
Old 11-04-2014, 08:32 AM   #11
Terry,NJ
Terry,NJ's Avatar
Go to my profile and look at "My 30 Coupe" I just completed this job myself. Terry
Terry,NJ is offline   Reply With Quote
Old 11-04-2014, 10:04 AM   #12
slackcat
slackcat's Avatar
Good work.
1926 T Speedster
Old 11-04-2014, 10:17 AM   #13
sethkestenbaum
sethkestenbaum's Avatar
How necessary/helpful is it to use an engine leveler?
Seth Kestenbaum
www.oldcarroadtrip.com
sethkestenbaum is offline   Reply With Quote
Old 11-04-2014, 11:15 AM   #14
mshmodela
mshmodela's Avatar
Two questions:
Not sure if this is what your need but as a newbie, I had to replace the GAV needle valve and wondered how to break the rod disconnected myself.
https://www.youtube.com/watch?v=Qqt0ZFusFQg
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 11-04-2014, 12:22 PM   #15
California Travieso
Send a message via Yahoo to California Travieso
Slackcat,
You should have taken your father-in-law out the garage and given him a wench. More fun than chating with the ladies.
California Travieso is offline   Reply With Quote
Old 11-04-2014, 04:27 PM   #16
Tom Wesenberg
They are nice, but I still don't have one. It's not a bad job without one.
Old 11-05-2014, 07:21 AM   #17
slackcat
slackcat's Avatar
Not necessary but helpful when by yourself. I had it for another car where I wanted to install an engine and tranny as one unit. On the A it let me angle the engiine in easier and not have to remove the headlight bar.
1926 T Speedster
