07-01-2014, 12:44 PM | #1 |
changing plugs every 100 miles!!
Hi all...i have a 8ba flathead and i'm frustrated cause my spark plugs don't work more than 100miles +-....!!!i have changed all wires and i put a pertronix kit and new coil from bubba.....but the problem is not solved...for some time engine runs good and than starts to crakle and runs rought....can you suggest me some of the causes?thanks a lot!
07-01-2014, 12:50 PM | #2 |
Re: changing plugs every 100 miles!!
What are the plugs like when you take them out? Is the motor running over-rich? (too much fuel?)
Mart. |
07-01-2014, 01:01 PM | #3 |
What brand of plugs and heat range are you using?
Ed |
07-01-2014, 01:07 PM | #4 |
plugs are black with residual of combustion....that's a problem that i have before i put the pertronix kit ,new coil and wires......hey that's a car i buy from a guy in uk some years ago.....is name is Simeon Roberts.......by the way.....when i start the engine i have Always a little popping or crakling.....after some km i notate that the issue became insistent....engine was stock with a 97 now has a navarro intake with 97s ....i buy the new one in uk......
07-01-2014, 01:08 PM | #5 |
plugs are ngk b6l....Ed....distr is a mallory with mechanical advance....i read somewhere that this mallory are not well tuned for the flathead....i don't have a kit to register the internal advance....
07-01-2014, 01:09 PM | #6 |
07-01-2014, 01:12 PM | #7 |
are you running those little four inch paper air filters? They dont work for long and maybe thats the problem. Maybe try a different brand of plugs.
07-01-2014, 01:19 PM | #8 |
07-01-2014, 01:27 PM | #9 |
I had that same problem once. there was a bunch of those china filters that would not breathe. I kept fowling plugs and finally realized that my breather was the problem. switched to K&N element and have not had the problem since.
07-01-2014, 02:37 PM | #10 |
The filter screens are the root of the problem.
I just went through this same thing on a friends '32 with 2 strombergs. sooty plugs & ran like it had a bad fuel pump. After much fussing, finally took away the screens & it ran like it's supposed to. |
07-01-2014, 02:50 PM | #11 |
If the screen removal did not help try NGK spark plugs if your not already using them. NGK offers two heat ranges for the flathead the plug numbers are B-4 and B-6 the B-4 plug is the hotter plug. If your using champion H-10 plugs I gave up on them years ago their made in mexico and and in my opion are junk.
Autolit also offers a plug for the flathead part number 216 its much better than champion but not as good as NKG plugs. |
07-01-2014, 03:25 PM | #12 | |
07-01-2014, 03:29 PM | #13 |
42MERC....your friend took away the screens...but what use him for air filter?only the scoops without protection for carbs?thanks for the interest..!
07-01-2014, 03:32 PM | #14 |
Let us know how the hotter plugs work. Also interested in the screens issue as I have that setup on an engine I am currently getting ready to run.
07-01-2014, 03:47 PM | #15 |
What kind of carb / carb's ?
Nomad |
07-01-2014, 03:50 PM | #16 |
[QUOTE=rodderbilly;903180....... now has a navarro intake with 97s ....![/QUOTE]
As he said above. DD |
07-01-2014, 03:59 PM | #17 |
07-01-2014, 04:01 PM | #18 |
I've only ever messed with 94's but some things are universal.
Over rich could be caused by: Fuel pressure too high. Needle valve not sealing (debris on seat) Punctured or damaged float Fuel level set too high. Main jets too big. Damaged power valve (94 only) Filter clogged. Mart. |
07-01-2014, 07:42 PM | #19 |
rodderbilly, Take a good close up photo of each plug tip and post it, if possible. thanks.
07-01-2014, 09:18 PM | #20 |
It does sound as if your running too rich. Do you know the size of the jets and the power valves in the two 97'S??? Does the engine use oil?? You may want to contact Uncle Max for his suggestion on jet size, he was spot on for my 2-97's Send him an email or personal message here on the ford barn.
